Page 1 of 4 1 2 3 4
What Do YOU Want Howards Cams To Make For Mopars? #267858
03/27/09 12:37 AM
03/27/09 12:37 AM
Wellington, Ohio (20 minutes f...
MrMoparRacing Offline OP
Howards Cams currently makes these items for
Small Block Mopar:
Hydraulic Flat Tappet Camshafts
Mechanical Flat Tappet Camshafts
Steel Billet Mechanical Roller Camshafts
Billet Timing Sets
Cam Correct
Hydraulic Lifters
Mechanical Lifters
“THE ORIGINAL” Direct Lube Solid Lifters
Mechanical Racing Roller Lifters (Vertical Bar)
Race Valve Springs, Retainers, Locks, Seals, Caps
Distributor Gears
Ultimate Duty Billet Connecting Rods
Big Block Mopar:
Mechanical Flat Tappet Camshafts (3 Bolt)
Steel Billet Mechanical Roller Camshafts (3 Bolt)
Billet Timing Sets (singe & three bolt)
Cam Correct
Hydraulic Lifters
Mechanical Lifters
Distributor Gears
Howards Cams is wanting to know what MOPAR customers want Howards Cams to make that they currently do not offer. Rocker arms, crankshafts, connecting rods, pushrods, stroker pistons ect. Please be specific to exact sizes, such as rod length, stroke, piston bore, ect. Your input is highly valued!
Howards Cams products are MADE IN THE USA!
Howards Cams products are now available at Summit Racing Equipment!
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267859
03/27/09 12:40 AM
03/27/09 12:40 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I like the cool box for storing cams.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: goldmember] #267860
03/27/09 01:04 AM
03/27/09 01:04 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
An "affordable" rocker setup for the max wedge victors. I bet they would sell like hotcakes. Well, as hotcakey as mopar can get anyways lol.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267861
03/27/09 01:22 AM
03/27/09 01:22 AM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
Hot Hydraulic roller cams and hydraulic roller lifters for big blocks and small blocks with stock displacements, and especially for hot street/strip stroker motors.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267862
03/27/09 01:50 AM
03/27/09 01:50 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
An affordable quality H-beam rod and 440 6pak style flat top pistons for 440 Mopar.The rods should be stock size(.990 pin OK)6.76 length,3.75 stroke,pistons in +.020,.030.040 and .060 oversizes from 4.320 standard bore.
Nautilus Racing-
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Chris2581] #267863
03/27/09 02:04 AM
03/27/09 02:04 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Same with a 383. Lots of guys still building those. Just look in the Q&A every now and then.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: RemCharger] #267864
03/27/09 02:10 AM
03/27/09 02:10 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Yes to the 383 parts also!! I should have mentioned those in my original post.
Nautilus Racing-
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Chris2581] #267865
03/27/09 04:14 AM
03/27/09 04:14 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
affordable ($3-400) rockers / alum and SS , in 1.6 AND 1.7 ratio .
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: BCFKody] #267866
03/27/09 07:22 AM
03/27/09 07:22 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
A good hyd roller for s/b strokers.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267867
03/27/09 07:31 AM
03/27/09 07:31 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Add Mopar SB to their Pro-Max line of direct lube roller
lifters......and keep the prices sane.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: S/ST 3040] #267868
03/27/09 08:03 AM
03/27/09 08:03 AM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
W2 rockers affordable
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: sickhemi] #267869
03/27/09 08:41 AM
03/27/09 08:41 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
TA rockers affordable. i really really want a set of the harland sharps but I cant afford to spend $1000 buck on the set.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: sickhemi] #267870
03/27/09 08:45 AM
03/27/09 08:45 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd love a 4" strock SBM USA forged/USA machined crank in the same price range as their USA forged/USA machined SBC cranks, maybe a cast crank option in the $400 range if it was cast/machined in the USA.
I'd really, really love them to make their powderforged rods in SBM size, or at least 6.125" SBC, with the little end designed such that they could have a SBM pin size option without having to do a lot of spendy rework. those powderforged rods look like they'd be awesome for a street build up, or any application where you're looking at under 600HP or so.
2017 Grand Cherokee Overland
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: patrick] #267871
03/27/09 09:25 AM
03/27/09 09:25 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I just installed my new Howard's cam earlier this week (haven't fired yet).
Y'all have great customer service and great products. Keep up the good work.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: 1968RR] #267872
03/27/09 10:51 AM
03/27/09 10:51 AM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
They move from Oshkosh?
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: 1968RR] #267873
03/27/09 11:24 AM
03/27/09 11:24 AM
organ
maximum entropy Offline
organ
rocker arms! offset for indy, victor, et cetera.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267874
03/27/09 12:42 PM
03/27/09 12:42 PM
Sweden
sbdemon Offline
sbdemon  Offline
Sweden
W2/W5 rockers 1.6 1.7 ratio.
sbdemon
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267875
03/27/09 06:08 PM
03/27/09 06:08 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Big Block
Forged Cranks: 4.25", 4.375, 4.5", 4.75" strokes, 2.2" x 2.009" wide rod journal on all, 2.75" mains, 8 bolt
Forged Crank: 3.375" stroke, 2.375" X 2.050 wide rod journal, 2.75" mains, 8 bolt
Billet Rods: 6.76" long, 2.375 journal, 1.014" width, .990 pin
Billet rods: 6.86" long, 2.375 journal, 1.014" width, .990 pin
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267876
03/27/09 06:30 PM
03/27/09 06:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you offer a composite (not bronze) billet-cam compatible distributor drive gear for other brands (like Comp and Crane do), how about tooling one up for the Mopar crowd? Having to run a bronze gear on a street car is one of the things that's turned me off from switching to a solid roller in my 440.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: sbdemon] #267877
03/27/09 07:08 PM
03/27/09 07:08 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
sbdemon
Page 1 of 4 1 2 3 4
