Friends car running hot on methanol ? #2677456
07/14/19 11:30 PM
07/14/19 11:30 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
He's running a 470, 35* timing shifts at 7000rpm 1150 alky carb. Don't know all the particulars. But gets back to the pits and its over 200*. Any ideas?
Re: Friends car running hot on methanol ? [Re: merpar] #2677465
07/15/19 12:27 AM
07/15/19 12:27 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
if the cooling system is good it is probably lean
Re: Friends car running hot on methanol ? [Re: CSK] #2677542
07/15/19 09:55 AM
07/15/19 09:55 AM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Cooling system is more than enough. I can't convince him it has to be lean.
Re: Friends car running hot on methanol ? [Re: merpar] #2677544
07/15/19 09:57 AM
07/15/19 09:57 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
it might be jetted good for WOT, but driving back to the pits,cruise mode it could be VERY lean
Re: Friends car running hot on methanol ? [Re: CSK] #2677582
07/15/19 11:53 AM
07/15/19 11:53 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Its lean or the timing is retarded.
Re: Friends car running hot on methanol ? [Re: fbs63] #2677599
07/15/19 12:22 PM
07/15/19 12:22 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Possible vacum leak
Kevin
Re: Friends car running hot on methanol ? [Re: merpar] #2677637
07/15/19 01:16 PM
07/15/19 01:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
If the exhaust smell doesn't burn your eyes at idle it is to lean shruggy
Tell him to please fatten up the idle for one run and see if it is the cure or not up
My bracket car runs on E85 with no radiator, it has two small oil coolers for the water. It is hard for me to get heat in the motor in the mornings but once it is warmed up it is harder for me to get it to cool down in a hurry whiney
Most guys that have radiators tell me there cars will cool down around 20 degrees after a 1/4 mile run driving back to the pits work If it doesn't that fatten up the idle until it does work
