Small Block Mechanica Fuel Pumps #2676560
07/11/19 01:01 PM
07/11/19 01:01 PM
Colorado front range
BcudaChris Offline OP
I've seen some Carter fuel pump kits on Jegs. Does anyone know if they will fit the Carter 6270?
If so, will that kit fit the Holley 360-11 or edelbrock 1720?
Reason I'm asking is that I have the quick fuel branded holley pump and it is spewing out the top hole.
Chris
Re: Small Block Mechanica Fuel Pumps [Re: BcudaChris] #2676714
07/12/19 06:37 AM
07/12/19 06:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A few years ago I tried to get a kit for my old Holey that I bought in the 70s.Not avaliable.Had to go new pump.Dont know if the Carter will work.I guess you would have to see if the diaphrams etc are the same.Rocky
Chrysler Firepower
Re: Small Block Mechanica Fuel Pumps [Re: BcudaChris] #2676773
07/12/19 10:53 AM
07/12/19 10:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Chris
Just had the lower pressure Carter small block bolt 2-part spit out the top a few weeks ago.
It was 7 years old.
The chrome edelbrock is same body as carter but with bigger fitting threads.
Basic rebuild kit same, but I don’t know how the three valves relate to the pressure rating.
Re: Small Block Mechanica Fuel Pumps [Re: autoxcuda] #2677261
07/14/19 09:06 AM
07/14/19 09:06 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Pressure is controlled by the big spring (relative to the diaphram area but those all pretty close in size on a 70 up small block pump).
Catherder's explantion is really clear:
https://www.tapatalk.com/groups/racingfuelsystems/viewtopic.php?f=28&t=1032#p9568
Re: Small Block Mechanica Fuel Pumps [Re: autoxcuda] #2677588
07/15/19 12:05 PM
07/15/19 12:05 PM
Thanks for the feedback everyone.
Edelbrock pump and it is visually identical to the Quick Fuel pump I have.
Anyway, on the road but want to rebuild the other as a spare. I have heard Carter has a pretty good tech line, I might see what they say about a rebuild kit for the Carter.
