I've seen some Carter fuel pump kits on Jegs. Does anyone know if they will fit the Carter 6270?
If so, will that kit fit the Holley 360-11 or edelbrock 1720?
Reason I'm asking is that I have the quick fuel branded holley pump and it is spewing out the top hole.
Chris
Just had the lower pressure Carter small block bolt 2-part spit out the top a few weeks ago.
It was 7 years old.
The chrome edelbrock is same body as carter but with bigger fitting threads.
Basic rebuild kit same, but I don’t know how the three valves relate to the pressure rating.
