Re: Starter clicking
[Re: 451Mopar]
#2675912
07/09/19 10:11 AM
07/09/19 10:11 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When you put a powerglide behind a Mopar engine it’s never a bolt it on and go situation. Every setup is different and has to be setup for proper engagement. Some I had to cut the nose off, some needed a 1/2 inch shim, and some needed 1/8.
[Re: pittsburghracer]
#2675966
07/09/19 12:34 PM
07/09/19 12:34 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
[Re: second 70]
#2675990
07/09/19 01:25 PM
07/09/19 01:25 PM
RapidRobert
"machine gun" clicking at the starter is inadequate voltage (amperage) at the starter (solenoid) itself. Start at the beginning (battery) & work downstream including ground paths
[Re: RapidRobert]
#2676002
07/09/19 02:15 PM
07/09/19 02:15 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Is all of the current for the solenoid being run through the NS switch? Stock starter relay?
Change it over to a Ford style relay, jumper on the starter for starter solenoid, type set-up. Fix the grounds, especially if you are using rubber mounts.
[Re: CMcAllister]
#2676012
07/09/19 03:06 PM
07/09/19 03:06 PM
Posts: 20,623 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
It may be a wiring issue. My brother has the Ford solenoid and his mini starter did it. Had to carry a small hammer around and tap the starter every so often. His buddy had him switch the wiring around and that solved it. I will ask him what he did to fix it...
Edit: Do you have a Ford solenoid in the car? They can be wired wrong and the car will still start sometimes, and sometimes not.
[Re: Dyno Donnie]
#2676151
07/10/19 03:07 AM
07/10/19 03:07 AM
Posts: 2,924 A shed in England
Tig
A shed in England
I'm guessing you have an alignment problem. If the starter is clicking but the bendix isn't throwing out its jammed. Could be the engagement / mesh is off and pushing the bendix off to one side, after a few goes it's enough to damage it and then jam.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Neil]
#2676203
07/10/19 10:59 AM
07/10/19 10:59 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
The correct way is to run both big cables to the large post on one side, one from battery positive, the other to the main starter post. The opposite big post needs the small wire to the small post on the starter solenoid.
The incorrect way he had it before on the two big battery positive to one side of the large Ford solenoid post and the other to the big post cable to the main starter positive. This overheats the contacts inside the solenoid and makes them stick when the two large cables are on opposite sides of the Ford solenoid. Your car may not have a GM style relay like my brothers car has.
He did give me a diagram of it that I can scan and e-mail to you if you need it. Sorry but this is definitely wrong. You are not using the ford solenoid for its intentions. the purpose is to put the load across the solenoid that's what they are designed for. on the starter run a wire from the large terminal to the small one, put the main battery terminal on one side of the ford solenoid the other go's to starter. So when it is activated it will power up the wire going down to starter.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2676216
07/10/19 11:30 AM
07/10/19 11:30 AM
RapidRobert
From what I understand there is a "continuous duty" furd solenoid that you run the main cables on either side of it
[Re: RapidRobert]
#2676219
07/10/19 11:34 AM
07/10/19 11:34 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
From what I understand there is a "continuous duty" furd solenoid that you run the main cables on either side of it A starter should be run with an "intermittent" duty unit. They are built for that purpose. And cables can be swapped either way on the main lugs. They aren't polarity sensitive. It's just a switch connecting the two together.
[Re: Neil]
#2676330
07/10/19 04:48 PM
07/10/19 04:48 PM
JAKE68
Shelby mi.
He did give me a diagram of it that I can scan and e-mail to you if you need it. If you wire it the way you explain your only using the solenoid to activate the small wire which is then the same as what a mopar is already wired to do.
JAKES AUTOMOTIVE
