Hole Pattern for Parachute Enclosure #2675490
07/08/19 11:52 AM
07/08/19 11:52 AM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Can someone please tell me the 4 hole pattern dimensions for a Parachute Enclosure? As well as hole size? I'm assuming that this is a "standard" pattern regardless of Chute Brand?
Re: Hole Pattern for Parachute Enclosure [Re: STEFF] #2675688
07/08/19 07:09 PM
07/08/19 07:09 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
My SW kit uses 4 holes in a 6x6 bolt pattern for my "430' Stroud chute.
Re: Hole Pattern for Parachute Enclosure [Re: STEFF] #2675692
07/08/19 07:17 PM
07/08/19 07:17 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
No standard pattern that i know of. Just match the dimensions on the mounting plate.
My chassis builder went with 3-hole mounting
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Hole Pattern for Parachute Enclosure [Re: jughed] #2675712
07/08/19 08:24 PM
07/08/19 08:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Depends on the size of the pack which depends on the size of the chute, if you're using the 4 corner fasteners. We just use a small flange in the center for a conventional chute. Doesn't take much to hold the chute pack.
Re: Hole Pattern for Parachute Enclosure [Re: CMcAllister] #2675743
07/08/19 09:17 PM
07/08/19 09:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As stated there is no "standard" answer for that question. Most of the plates you see are around 6x6 but doesn't mean anything. Every chute I have bought and used had no holes for mounting at all. You cut the bag for screws.
Re: Hole Pattern for Parachute Enclosure [Re: Al_Alguire] #2675847
07/09/19 06:09 AM
07/09/19 06:09 AM
STEFF Offline OP
STEFF  Offline OP
Thanx Guys!!
