What torque converter #2674767
07/06/19 10:55 AM
07/06/19 10:55 AM
Long Island New York
Mag162 Offline OP
Mag162  Offline OP
Came in a 69 Roadrunner?
I have a 69 440 HP out of a Roadrunner in my 67 fury wagon mated to the original trans. The 440HP motor has been punched .030. and has a mopar purple cam in it. Not sure of the cam specs
Car has a 3.90 rear in it. Its a pig.
I'm assuming a swap in converters to the Road runner converter would wake this thing up Maybe?
Re: What torque converter [Re: Mag162] #2674792
07/06/19 11:52 AM
07/06/19 11:52 AM
moparx Offline
moparx  Offline
the info from my 69 charger FSM states the 440/4bbl torque converter is a 10 1/2" with a 2000-2300 stall. [plymouth would be the same.]
you may consider a change to a 2800-3000 stall. that would wake it up for sure.
best to talk to someone like A&A to get their recommendations.
beer
Re: What torque converter [Re: moparx] #2674827
07/06/19 12:51 PM
07/06/19 12:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No 440 prior to '73 came with anything but an 11 3/4" (12") converter. A '69 383 RR would have come with a 10 3/4" (11") converter.
Re: What torque converter [Re: John_Kunkel] #2675130
07/07/19 11:00 AM
07/07/19 11:00 AM
moparx Offline
moparx  Offline
you're correct john. i mis-typed. should have been 10 3/4 [11"].
however, page 21-94 states the A-727 high performance versions came with the converter above.
i will defer to your 11 3/4" [12"] as gospel because you have way more experience than i do.
i stand corrected, even though i quoted from the 69 coronet/charger FSM.
beer
Re: What torque converter [Re: moparx] #2675174
07/07/19 12:58 PM
07/07/19 12:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, another case where the factory literature conflicts with itself. As you can see from the parts manual, there was only one converter available with the 440, Hi-PO of not. The 764 converter is the small one, the 586 is the large one.
Re: What torque converter [Re: John_Kunkel] #2675472
07/08/19 10:44 AM
07/08/19 10:44 AM
moparx Offline
moparx  Offline
thanks john ! up
beer
Re: What torque converter [Re: Mag162] #2675495
07/08/19 12:02 PM
07/08/19 12:02 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Your cam specs and compression are important when choosing a converter otherwise your flying blind! Any way to find out?
Re: What torque converter [Re: R/T1968R/T] #2675857
07/09/19 07:19 AM
07/09/19 07:19 AM
Mag162 Offline OP
Mag162  Offline OP
Yeah Im working on those numbers as we speak
