HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? #2671598
06/29/19 02:28 PM
06/29/19 02:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello!
I was wondering if such a rod was ever manufactured by Ma Mopar:
a 6.86" length HEMI rod
with a small end for a 1,09" wrist pin.
NASCAR rod maybe???
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: domingo] #2671649
06/29/19 06:23 PM
06/29/19 06:23 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
If I remember correctly KB made an aluminum rod that size.
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: domingo] #2671663
06/29/19 06:57 PM
06/29/19 06:57 PM
PA
1118Steve Offline
1118Steve  Offline
PA
Yes. The early 64-65 race hemis had that rod. The 1.03 pin didn't begin until the street Hemi in 66.
"Old Age and Treachery beats youth and enthusiasm"
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: 1118Steve] #2671667
06/29/19 07:05 PM
06/29/19 07:05 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
And was that rod bronze bushed or not?
Would that rod be just the same forging as a street hemi rod? Just that it wasnt bronze bushed?
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: domingo] #2671884
06/30/19 11:50 AM
06/30/19 11:50 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted by domingo
Hello!
NASCAR rod maybe???
Yes, very early 426 Hemi, pressed pin.
2011 Drag Pak Challenger
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: rickseeman] #2671941
06/30/19 01:46 PM
06/30/19 01:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hello!
NASCAR rod maybe???
GOTCHA.
So I guess if you just take some 66-71 street hemi rods and drive out the bronze bushings and resize the small end to press fit a 1.09 wrist pin, you would basically have a 64/65 HEMI rod?
Sre they the same forging? Or are the press fit rods any beefier on the small end?
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: domingo] #2671943
06/30/19 02:05 PM
06/30/19 02:05 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Hello!
NASCAR rod maybe???
GOTCHA.
I'm not sure what the small end size would be if you took the bushing out. I can't imagine why anybody would do such a thing. I have seen the old press fit rods but I didn't pay any attention to them. Whatever you're thinking, forget about it. Floating in bronze is better than pressed in steel.
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: domingo] #2671975
06/30/19 03:51 PM
06/30/19 03:51 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
[/quote]
Sre they the same forging? Or are the press fit rods any beefier on the small end? [/quote]
The 1964 rod had a foot width of 3.72 inch if you have a street rod to compare with. I-section was 0.35 sq inch, max rpm 7000.
Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE? [Re: MikeN] #2673459
07/03/19 02:08 AM
07/03/19 02:08 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Did the NASCAR rods have the 1.09" pin? Those big heavy suckers with the 1/2" rod bolts.
https://books.google.com/books?id=I...e&q=nascar%20Hemi%20rods&f=false
Floyd Lippencott IV
