Re: HEMI rod 6.86" length and 1.09" pin: WAS IT EVER MADE?
[Re: domingo]
#2671663
06/29/19 06:57 PM
06/29/19 06:57 PM
Posts: 24 PA
1118Steve
PA
Yes. The early 64-65 race hemis had that rod. The 1.03 pin didn't begin until the street Hemi in 66.
"Old Age and Treachery beats youth and enthusiasm"
[Re: 1118Steve]
#2671667
06/29/19 07:05 PM
06/29/19 07:05 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Yes. The early 64-65 race hemis had that rod. The 1.03 pin didn't begin until the street Hemi in 66. And was that rod bronze bushed or not? Would that rod be just the same forging as a street hemi rod? Just that it wasnt bronze bushed?
[Re: domingo]
#2671884
06/30/19 11:50 AM
06/30/19 11:50 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Hello!
I was wondering if such a rod was ever manufactured by Ma Mopar:
a 6.86" length HEMI rod
with a small end for a 1,09" wrist pin.
NASCAR rod maybe??? Yes, very early 426 Hemi, pressed pin.
2011 Drag Pak Challenger
[Re: rickseeman]
#2671941
06/30/19 01:46 PM
06/30/19 01:46 PM
domingo
EL Master
EL Master
Lima, Peru
Hello!
NASCAR rod maybe??? Yes, very early 426 Hemi, pressed pin. GOTCHA. So I guess if you just take some 66-71 street hemi rods and drive out the bronze bushings and resize the small end to press fit a 1.09 wrist pin, you would basically have a 64/65 HEMI rod? Sre they the same forging? Or are the press fit rods any beefier on the small end?
[Re: domingo]
#2671943
06/30/19 02:05 PM
06/30/19 02:05 PM
rickseeman
Stuttgart, Arkansas
Hello!
NASCAR rod maybe??? Yes, very early 426 Hemi, pressed pin. GOTCHA. So I guess if you just take some 66-71 street hemi rods and drive out the bronze bushings and resize the small end to press fit a 1.09 wrist pin, you would basically have a 64/65 HEMI rod? Sre they the same forging? Or are the press fit rods any beefier on the small end? I'm not sure what the small end size would be if you took the bushing out. I can't imagine why anybody would do such a thing. I have seen the old press fit rods but I didn't pay any attention to them. Whatever you're thinking, forget about it. Floating in bronze is better than pressed in steel.
[Re: domingo]
#2671975
06/30/19 03:51 PM
06/30/19 03:51 PM
Posts: 81 Sweden
MikeN
Sweden
[/quote] So I guess if you just take some 66-71 street hemi rods and drive out the bronze bushings and resize the small end to press fit a 1.09 wrist pin, you would basically have a 64/65 HEMI rod? Sre they the same forging? Or are the press fit rods any beefier on the small end? [/quote]
The 1964 rod had a foot width of 3.72 inch if you have a street rod to compare with. I-section was 0.35 sq inch, max rpm 7000.
