Page 31 of 48 1 2 29 30 31 32 33 47 48
Re: Modern Bullitt build [Re: larry4406] #2600509
01/02/19 04:40 PM
01/02/19 04:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By larry4406
Pat - impressive work on the dash and wiring! That harness kit is pretty interesting.
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #2609653
01/20/19 11:54 PM
01/20/19 11:54 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Started the restoration on the grill which is in very good condition but as with most Charger grills there are a few cracks that need to be repaired. After cleaning up and painting most of the hardware I started by fixing some of the cracks and broken parts using steel wire to get a mechanical fastener prior to using epoxy with chopped fibers.
Re: Modern Bullitt build [Re: Keepat] #2609985
01/21/19 06:02 PM
01/21/19 06:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Melting staples into the plastic using a soldering iron to hold the cracked parts of the plastic together prior to epoxy. After melting the staple flush with the outer surface I would bend over the staple on the inside and again melt and bend it flush.
Re: Modern Bullitt build [Re: Keepat] #2611708
01/24/19 05:54 PM
01/24/19 05:54 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
You have given me many ideas to think about Pat.
Re: Modern Bullitt build [Re: Keepat] #2616430
02/03/19 02:34 PM
02/03/19 02:34 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The grill repairs are done and it’s all sanded to 600 grit, time for paint!
Pat
screen capture software
Re: Modern Bullitt build [Re: Keepat] #2616619
02/03/19 09:53 PM
02/03/19 09:53 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Looks good Pat!
Re: Modern Bullitt build [Re: Keepat] #2619186
02/09/19 08:55 PM
02/09/19 08:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finally received the backordered AAR radio so I could complete the dash. Radio is Bluetooth audio as well as hands-free phone, not sure how well it works but it looks and fits great!
Pat
fisto fallout 3
Re: Modern Bullitt build [Re: Keepat] #2619303
02/10/19 10:45 AM
02/10/19 10:45 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - the dash looks sweet!
That radio looks quite impressive! Link?
Re: Modern Bullitt build [Re: larry4406] #2619337
02/10/19 01:06 PM
02/10/19 01:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
http://www.radiosforoldcars.com/
Pat
Re: Modern Bullitt build [Re: Keepat] #2632348
03/13/19 04:39 PM
03/13/19 04:39 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Awesome, amazing, mind blowing build! Best build thread I ever saw! I am learning a lot here. Thanks! BTW... what brand of epoxy did you use on your grille repairs? And info on the fibers you added too.
Re: Modern Bullitt build [Re: Hooligan] #2637396
03/26/19 03:19 PM
03/26/19 03:19 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Sorry for the delayed response, The glue I used is called five-minute epoxy from West System, they also sell the chopped fibers and capasill use for a thickening agent. You can find both at West Marine.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2637904
03/27/19 10:14 PM
03/27/19 10:14 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Thank you
Pat
Not to worry Pat. Many thanks for the info. Looking forward to seeing more of your fabulous fabricating skills!
Re: Modern Bullitt build [Re: Hooligan] #2671946
06/30/19 02:24 PM
06/30/19 02:24 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I’m installing the vinyl top over the 4th of July holiday. So I started by putting all of the vinyl top trim so I know where to locate the final cut. For the last 3 years this top has been laying over my Trans Am or viper. It’s nice to have it laying on the charger now ;-)
Pat
how many years to become a forensic anthropologist
Re: Modern Bullitt build [Re: Keepat] #2671960
06/30/19 03:06 PM
06/30/19 03:06 PM
NJ
rdrnr6970 Online content
Your #1 source for current events
rdrnr6970  Online Content
NJ
Very cool!Nice paint and dash!
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Modern Bullitt build [Re: rdrnr6970] #2675879
07/09/19 09:01 AM
07/09/19 09:01 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the vinyl seams even and clamped at the front I glue the center 6” back to front. Then folding over the drivers side I glue over to the seam and then the same on the right side. After spraying the glue on both the roof and vinyl I put some plastic down to let me flip the vinyl over without sticking. Then holding and pulling the vinyl up I remove the plastic and stick the the vinyl down. Now with it glue seam to seam next will be down the pillars.
Pat
[Linked Image]fallout 3 all vaults
Re: Modern Bullitt build [Re: Keepat] #2675908
07/09/19 10:08 AM
07/09/19 10:08 AM
Boca Raton, Florida
jpilone Offline
jpilone  Offline
Boca Raton, Florida
Very impressive work!
Any idea on how much longer till it's moving under it's own power?
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: Modern Bullitt build [Re: jpilone] #2676081
07/09/19 08:05 PM
07/09/19 08:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I have given up on guessing when this car will be completed ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2679029
07/19/19 10:43 AM
07/19/19 10:43 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Pat
It's a hobby. Enjoy the ride...
69 GTX 68 Road Runner
Re: Modern Bullitt build [Re: JERICOGTX] #2679345
07/20/19 09:45 AM
07/20/19 09:45 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Had a setback on the vinyl top. There was a wrinkle on the driver side seam that I initially thought was from me over or under stretching the top when I glue that side down? But after investigating it a little closer it turned out the top was stitched crooked. I bought this top along with all of the interior components over 4 years ago from Legendary Auto Interior. I sent them pictures and a description of the problem and they quickly came back and said they would send me a new vinyl top. That’s first class customer service in my book! I was taught a long time ago by the guy I work for, don’t judge one by their mistakes but rather by their solutions!
Fortunately the top removed relatively easily and I was able to remove the contact cement by rubbing it with mineral spirits. I get to start over sometime next week when I receive the new top.
Pat
Re: Modern Bullitt build [Re: Keepat] #2689103
08/18/19 02:46 PM
08/18/19 02:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
New vinyl top with straight seams is gluing on nicely. Just need to glue down both A pillars and trimmer up.
Pat
[Linked Image]where is the nearest chase bank
[Linked Image]image upload
