Page 1 of 11 1 2 3 10 11
Hilborn EFI 512 Charger #2671566
06/29/19 01:11 PM
06/29/19 01:11 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Been wanting to go EFI, found a deal I could not pass up, always wanted this set up but the price said NO WAY until this came up on Moparts, took one intake apart & started grinding for Max wedge ports, got a little done but the heat was to much, I will just have to pace myself & get done what I can,may take awhile LOL. I am SO exited to get this for the Charger smile
68D69BE3-EF2D-4443-9F03-E0B2C7E25397.jpeg65585018_2348276858564343_3083866705567416320_n.jpg65444319_2349685058423523_7256831237866651648_n.jpg
Re: Hilborn EFI 512 Charger [Re: CSK] #2671568
06/29/19 01:13 PM
06/29/19 01:13 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
a
Re: Hilborn EFI 512 Charger [Re: CSK] #2671571
06/29/19 01:18 PM
06/29/19 01:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice.
Looks like they designed it to be made into MW size.
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2671574
06/29/19 01:24 PM
06/29/19 01:24 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Originally Posted by fast68plymouth
Nice.
Yes I called Hilborn before I bought it & they said the max wedge was the same casting as the 440 port.
The shadowing in the picture makes it look like I did not follow the contour of the port, but I did.
Re: Hilborn EFI 512 Charger [Re: CSK] #2671623
06/29/19 04:14 PM
06/29/19 04:14 PM
I wish that I had ask the seller what port size that injection was before you bought it, but I didn't realcrazy whiney shruggy
Re: Hilborn EFI 512 Charger [Re: CSK] #2671624
06/29/19 04:17 PM
06/29/19 04:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Looks great, have fun with it.
Having said that, what do you expect to get by way of results (other than the known EFI benefits)?
Boffin Emeritus
Re: Hilborn EFI 512 Charger [Re: polyspheric] #2671639
06/29/19 05:23 PM
06/29/19 05:23 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
I did a lot of EFI Individual runner intakes on Harley's back before I got sick, IR set ups & longer runner will idle MUCH better with a large cam, much better drivability, low & midrange torque is much better, I have posted this dyno sheet before , this is my old 2005 Dyna FXDWG, 94.2 cid EFI, the blue lines are with approx 8in long runner, the red lines are 24in IIRC, nothing else was change, my Charger is a street car , it is already a blast to drive , this should step it up a notch or 2, plus it will look awesome sticking out of the hood.
Re: Hilborn EFI 512 Charger [Re: CSK] #2671654
06/29/19 06:36 PM
06/29/19 06:36 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Let me know if you need any remote tuning help with the Holley.
efiexpert.com
Re: Hilborn EFI 512 Charger [Re: CSK] #2671677
06/29/19 07:41 PM
06/29/19 07:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I agree, but AFAIK the only stack injection nearly large enough is the Crower for BBC, which has 2.90" butterflies.
Boffin Emeritus
Re: Hilborn EFI 512 Charger [Re: Mopar_Rich] #2671686
06/29/19 08:00 PM
06/29/19 08:00 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
efiexpert.com
I will , Thank you Rich
Re: Hilborn EFI 512 Charger [Re: polyspheric] #2671689
06/29/19 08:06 PM
06/29/19 08:06 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Depends on how much power you want, the set up I have flows way more than I need for the power level I am at now, 2.9 butterflies are in the 1000 + hp, I am in the low 600, street car, overdrive A/C . Hilborn does make the 3" bore, My butterflies are 2.4375,the runners are 2.5 id, do the math my intake valve is 2.14, the id of the intake seat is 1.94
Re: Hilborn EFI 512 Charger [Re: CSK] #2671695
06/29/19 08:28 PM
06/29/19 08:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Re: Hilborn EFI 512 Charger [Re: CSK] #2671749
06/29/19 11:02 PM
06/29/19 11:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You'll be fine, I thought you had the smaller stuff.
Boffin Emeritus
Re: Hilborn EFI 512 Charger [Re: polyspheric] #2671765
06/29/19 11:38 PM
06/29/19 11:38 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Such a unique setup, so cool!
Rich H.
Esse Quam Videri
Re: Hilborn EFI 512 Charger [Re: ZIPPY] #2671768
06/29/19 11:43 PM
06/29/19 11:43 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Thanks Everyone, 1/2 way there,it has been awhile since I have done any port work & it shows lol, good thing that looks don't make power.
Re: Hilborn EFI 512 Charger [Re: CSK] #2671772
06/30/19 12:00 AM
06/30/19 12:00 AM
New York, USA
Chargerfan68 Offline
New York, USA
I agree....so cool and rarely see these setups poking through the hoods of Chargers. It will be sick looking! I admire your ambition. up
Re: Hilborn EFI 512 Charger [Re: CSK] #2671792
06/30/19 03:16 AM
06/30/19 03:16 AM
So cal
E
EFI DART Offline
EFI DART  Offline
E
So cal
IR MOPARS RULE !!!
The sound of my 440" Mopar all Detroit Iron engine except for the Aluminium IR Intake ....!
.040" Over HP 440 Block
Factory Steel Crank
Pro Ported 2.08/1.74 452 Motor home heads
.528" MP Solid Old Gold Crane 1.6 Roller Rockers
SP/JE pistons & Rings 10:7:1
Manley Rods
On the video it breaks traction @ 55 mph <You can hear the rev Limiter soft cut the ign @ 6,300 RPM, ahh the joys of crisp digital EFI Tuning>
hit me up for any advice chargerwork
Moparaaaaaaars
Re: Hilborn EFI 512 Charger [Re: CSK] #2671851
06/30/19 10:29 AM
06/30/19 10:29 AM
moparx Online content
moparx  Online Content
glad you got such a deal ! as a fellow charger owner, and having the same health problem you do, i follow your exploits.
that is gonna look fantastic sticking out of your hood ! boogie
beer
Re: Hilborn EFI 512 Charger [Re: moparx] #2671863
06/30/19 10:53 AM
06/30/19 10:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow that looks like one cool setup. up Good luck with it. Ron
Re: Hilborn EFI 512 Charger [Re: 383man] #2672005
06/30/19 05:13 PM
06/30/19 05:13 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Finished ports to Max wedge, and reassembled them.
