Fuel tank sending units
#2671075
06/28/19 11:18 AM
06/28/19 11:18 AM
Posts: 1,376 Houston,Tx.
Lee446
Houston,Tx.
I need a new 3/8 sending unit for my 70 Cuda. Has there been any improvements in the last few years in these? I have bought a few for other Mopars thru the years and the accuracy was pretty dismal. Any particular brand or vendor you can recommend?
Re: Fuel tank sending units
[Re: HemiRick]
#2671163
06/28/19 02:25 PM
06/28/19 02:25 PM
RapidRobert
there was a prior thread (or two) on where a good one might be obtained (agreed they are the worst of the worst & definitely do your homework).
[Re: RapidRobert]
#2671398
06/29/19 06:00 AM
06/29/19 06:00 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
not too long ago someone posted a reply with a link to a company that will rebuild them to be accurate.ill see if i can find the link. sendingunitguy@gmail.com (315-712-0071). i havnt talked to them yet but im gunna.
[Re: gzig5]
#2672493
07/01/19 12:03 PM
07/01/19 12:03 PM
RapidRobert
Agreed, if there's a choice I'd ideally like to have a few gallons left when the needle hits E
[Re: Sniper]
#2672523
07/01/19 12:44 PM
07/01/19 12:44 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Reminds me of my riding days, run till you go empty, flip on the reserve and look for a station.
That worked ok till I forgot to flip back.
Did the same thing. Reminds me of my riding days, run till you go empty, flip on the reserve and look for a station.
Then I bought a new EFI bike with no reserve so that idea was out the window.
I didn't know the newer efi bikes lacked a reserve. Too bad.
[Re: DynoDave]
#2672708
07/01/19 07:45 PM
07/01/19 07:45 PM
Posts: 294 Maryland
MoparMike1974
Maryland
I just finished installing a meter match in my dart. It allows you to program set points to make the sending unit accurate. It will be a while before I get a chance to use it but in theory it looks like it should work great. It has several calibration points to compensate for odd shaped tanks. https://www.technoversions.com/MeterMatchHome.htmlA bonus is that the unit will provide the voltage to your gauge so the old limiter can be removed. Although you still need to power the temp gauge with a different source. The meter match instructions say it will only handle one gauge. I installed a 7805 regulator, and heatsink to power my temp gauge.
