904 vb ?? #2670018
06/26/19 01:19 AM
06/26/19 01:19 AM
Memphis,TN
J. Hammer Offline OP
Memphis,TN
I have a late 904 lock up trans that I am using a non lock up valve body and non lu converter and this gap is bothering me. Thanks in advance for advice.
Re: 904 vb ?? [Re: J. Hammer] #2670157
06/26/19 11:56 AM
06/26/19 11:56 AM
The VB will not sit down flush all the way seated? If so can you see where the interference is?
Re: 904 vb ?? [Re: J. Hammer] #2670170
06/26/19 12:12 PM
06/26/19 12:12 PM
Locomotion Offline
Locomotion  Offline
Did you change out the lock-up parts up front? Converter splines are different. Not sure about pump & other internals there.
Re: 904 vb ?? [Re: Locomotion] #2670267
06/26/19 03:30 PM
06/26/19 03:30 PM
Memphis,TN
Memphis,TN
Yes, I swapped out the lock up parts for non lock up parts. The concern is the small exposed gap the VB does not cover in the 1st pic above the front servo piston. Not sure if this is an issue or not? The valve body is from a non lock up trans as well.
Re: 904 vb ?? [Re: J. Hammer] #2670579
06/27/19 09:49 AM
06/27/19 09:49 AM
moparx Offline
moparx  Offline
something is preventing the VB from seating flush. remove it, then use a straight edge to find out what it is, then report back.
beer
Re: 904 vb ?? [Re: moparx] #2670586
06/27/19 09:55 AM
06/27/19 09:55 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if there is no passage in the vb or the case in that area it shouldnt be a prob as long as the gasket seals where it should
Re: 904 vb ?? [Re: moparx] #2670610
06/27/19 11:03 AM
06/27/19 11:03 AM
Memphis,TN
Memphis,TN
beer
The VB sits flush,thats not a problem. Thanks
Re: 904 vb ?? [Re: bonefish] #2670611
06/27/19 11:05 AM
06/27/19 11:05 AM
Memphis,TN
Memphis,TN
Never seen a gasket in this location. Thanks
Re: 904 vb ?? [Re: J. Hammer] #2670659
06/27/19 01:05 PM
06/27/19 01:05 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sorry that is correct(brain fert) but my passage comment still has me wondering.i wish i had a 999 here i could look at.
Re: 904 vb ?? [Re: bonefish] #2670738
06/27/19 02:48 PM
06/27/19 02:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FWIW, when the lockup transmissions were introduced in '78, the factory said the case was backward compatible with earlier years (probably back to '71).
Re: 904 vb ?? [Re: J. Hammer] #2671083
06/28/19 11:29 AM
06/28/19 11:29 AM
moparx Offline
moparx  Offline
beer
as the pic is a little blurry, and my old eyeballs are as well, it looked [to me anyway] the VB was not sitting flush, so i thought that was the gap you were talking about.
my fault. sorry. continue on.
beer
Re: 904 vb ?? [Re: moparx] #2671124
06/28/19 12:55 PM
06/28/19 12:55 PM
Memphis,TN
Memphis,TN
I should have circled the problem with a marker but think I've found the answer. Thanks
Re: 904 vb ?? [Re: J. Hammer] #2671148
06/28/19 01:57 PM
06/28/19 01:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So, what was the answer?
Re: 904 vb ?? [Re: burdar] #2671161
06/28/19 02:21 PM
06/28/19 02:21 PM
Memphis,TN
Memphis,TN
Not an issue. I'll know soon enough.
