Re: 904 vb ??
[Re: J. Hammer]
#2670157
06/26/19 11:56 AM
06/26/19 11:56 AM
RapidRobert
The VB will not sit down flush all the way seated? If so can you see where the interference is?
Re: 904 vb ??
[Re: bonefish]
#2670611
06/27/19 11:05 AM
06/27/19 11:05 AM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
if there is no passage in the vb or the case in that area it shouldnt be a prob as long as the gasket seals where it should Never seen a gasket in this location. Thanks
Re: 904 vb ??
[Re: J. Hammer]
#2670659
06/27/19 01:05 PM
06/27/19 01:05 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
if there is no passage in the vb or the case in that area it shouldnt be a prob as long as the gasket seals where it should Never seen a gasket in this location. Thanks sorry that is correct(brain fert) but my passage comment still has me wondering.i wish i had a 999 here i could look at.
Re: 904 vb ??
[Re: bonefish]
#2670738
06/27/19 02:48 PM
06/27/19 02:48 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FWIW, when the lockup transmissions were introduced in '78, the factory said the case was backward compatible with earlier years (probably back to '71).
Re: 904 vb ??
[Re: J. Hammer]
#2671083
06/28/19 11:29 AM
06/28/19 11:29 AM
Posts: 19,408 north of coder
moparx
something is preventing the VB from seating flush. remove it, then use a straight edge to find out what it is, then report back. The VB sits flush,thats not a problem. Thanks as the pic is a little blurry, and my old eyeballs are as well, it looked [to me anyway] the VB was not sitting flush, so i thought that was the gap you were talking about. my fault. sorry. continue on.
