Re: Strange A-1021 axle bearing
[Re: dakotahotrodder]
#2669936
06/25/19 08:41 PM
06/25/19 08:41 PM
Posts: 11,631 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I think that is a proprietary bearing made for the rear end/axle companies by Green or BCA. A-1021 comes with a new wedding ring as well. $38-40. Might be able to get the seal by itself.
[Re: DoctorDiff]
#2670605
06/27/19 10:46 AM
06/27/19 10:46 AM
Posts: 19,499 north of coder
moparx
those were the ones i posted pics of years ago that came with the narrowed dana i used in my 33 dodge humpback panel truck. thanks again doc ! edit : i have several master bearing catalogs i can possibly get an interchange number for these bearings, so if anyone has an olds number, or a number from a bearing that has the manufacturer's name on it, i may be able to come up with something we all can use. [hopefully]
[Re: moparx]
#2670653
06/27/19 12:56 PM
06/27/19 12:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
...or you could just call Strange, Moser, Randys or one of the bazillion places that sell their stuff and order a set that you know is correct for the weld ends and axles. ETA..Just for $#!+s and giggles, I spent 3 minutes searching for axle bearings based on the info Dr Diff provided and came up with a 3.150 x 1.531 x 1.474 bearing. Probably Chinese, no o-ring or groove cut for an o-ring.
