Strange A-1021 axle bearing #2669911
06/25/19 07:59 PM
06/25/19 07:59 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
I need a new rear axle bearing to replace the Strange A-1021 that has gone bad. I need to source it local if possible rather than order. It's the big ford bearing with the o-ring and seal on 1 side. Does anyone have a cross reference number for Timken, National, etc.? I have searched but not found anything. Thank you
Re: Strange A-1021 axle bearing [Re: dakotahotrodder] #2669936
06/25/19 08:41 PM
06/25/19 08:41 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I think that is a proprietary bearing made for the rear end/axle companies by Green or BCA. A-1021 comes with a new wedding ring as well. $38-40. Might be able to get the seal by itself.
Re: Strange A-1021 axle bearing [Re: CMcAllister] #2669960
06/25/19 09:24 PM
06/25/19 09:24 PM
South Dakota
South Dakota
I just ordered a set next day air from Summit as nothing was turning up correct. Thanks.
Re: Strange A-1021 axle bearing [Re: dakotahotrodder] #2670008
06/25/19 11:52 PM
06/25/19 11:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Its actually a late '50s Olds/Pontiac wheel bearing that auto part stores don't carry anymore.
Re: Strange A-1021 axle bearing [Re: DoctorDiff] #2670126
06/26/19 10:43 AM
06/26/19 10:43 AM
moparx Offline
moparx  Offline
doc, would that bearing be open to the inside, being lubed with the gear oil "slosh" ?
beer
Re: Strange A-1021 axle bearing [Re: moparx] #2670474
06/26/19 10:12 PM
06/26/19 10:12 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes. It is a Ford 9" style 3.15" ball wheel bearing, with an O-ring around the outside and NO inner seal.
Re: Strange A-1021 axle bearing [Re: DoctorDiff] #2670605
06/27/19 10:46 AM
06/27/19 10:46 AM
moparx Offline
moparx  Offline
those were the ones i posted pics of years ago that came with the narrowed dana i used in my 33 dodge humpback panel truck.
thanks again doc ! bow
beer
edit : i have several master bearing catalogs i can possibly get an interchange number for these bearings, so if anyone has an olds number, or a number from a bearing that has the manufacturer's name on it, i may be able to come up with something we all can use. [hopefully]
beer
Re: Strange A-1021 axle bearing [Re: moparx] #2670653
06/27/19 12:56 PM
06/27/19 12:56 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
...or you could just call Strange, Moser, Randys or one of the bazillion places that sell their stuff and order a set that you know is correct for the weld ends and axles. shruggy
ETA..Just for $#!+s and giggles, I spent 3 minutes searching for axle bearings based on the info Dr Diff provided and came up with a 3.150 x 1.531 x 1.474 bearing. Probably Chinese, no o-ring or groove cut for an o-ring.
Re: Strange A-1021 axle bearing [Re: CMcAllister] #2670949
06/27/19 11:32 PM
06/27/19 11:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You found the common '60s era Ford 9" bearing. It has a smaller ID than the Olds/Pontiac version.
