I need a new rear axle bearing to replace the Strange A-1021 that has gone bad. I need to source it local if possible rather than order. It's the big ford bearing with the o-ring and seal on 1 side. Does anyone have a cross reference number for Timken, National, etc.? I have searched but not found anything. Thank you
