...or you could just call Strange, Moser, Randys or one of the bazillion places that sell their stuff and order a set that you know is correct for the weld ends and axles. shruggy
ETA..Just for $#!+s and giggles, I spent 3 minutes searching for axle bearings based on the info Dr Diff provided and came up with a 3.150 x 1.531 x 1.474 bearing. Probably Chinese, no o-ring or groove cut for an o-ring.
If the results don't match the theory, change the theory.
