New Billet BBM Water Block !!
#2669861
06/25/19 05:49 PM
06/25/19 05:49 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Not sure of their motivation on this but is nice !!
CFE Racing Products, Inc.
Fresh out of the EZ-Bake Billet Oven!
Billet Water Jacketed Mopar Big Block • 10.725 Deck • Designed for Wedge Heads • 1.000 Inch Lifter Bores • Mopar or BBC Oiling System • 5.400 Cam-to-Crank • WATER JACKETED!!!!!!
Call us for more information at 586.773.6310
Re: New Billet BBM Water Block !!
[Re: unknown]
#2669919
06/25/19 08:17 PM
06/25/19 08:17 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
CFE Racing as in Carl Foltz in Eastpoint Michigan? I see its a 586 area code. Well if that's Carl's block, you can bet its a great piece. I totally agree. They do all of Prostocks billet intakes. I spoke to Carl last year. What a knowledgeable guy and easy to talk to.
[Re: Sammy]
#2669955
06/25/19 09:17 PM
06/25/19 09:17 PM
Posts: 6,146 Melbourne , Australia
LA360
I wonder if some Predator heads are going on top of it, for a Black Dart?
Noonan did a water jacketed Hemi block last year for Drag Week
Alan Jones
[Re: tubtar]
#2669967
06/25/19 09:37 PM
06/25/19 09:37 PM
Posts: 4,209 New York
polyspheric
New York
but then you need heads for them
and a crank, and a cam, and an intake manifold, and a pan (and motor mounts, a driveshaft?). IMHO this is only practical when you've reached a point of development where more inches is better use of money than the existing available parts. Makes boost look cheap, don't it?
Boffin Emeritus
[Re: Jerry]
#2669970
06/25/19 09:38 PM
06/25/19 09:38 PM
polyspheric
New York
Welding allows internal construction that cannot be cast
Boffin Emeritus
[Re: polyspheric]
#2669982
06/25/19 10:26 PM
06/25/19 10:26 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
and a crank, and a cam, and an intake manifold, and a pan (and motor mounts, a driveshaft?). IMHO this is only practical when you've reached a point of development where more inches is better use of money than the existing available parts. Makes boost look cheap, don't it? A thousand here..........a thousand there. Pretty soon , you're talking real money. But yeah.........I saw an 807 " Billet everything in a carbon fiber '71 Mustang at Houston Motorsports park last summer and I haven't been the same since. Bickel built , four stages of spray.......it was literally more car than they had track for.
[Re: polyspheric]
#2669985
06/25/19 10:28 PM
06/25/19 10:28 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
and a crank, and a cam, and an intake manifold, and a pan (and motor mounts, a driveshaft?). IMHO this is only practical when you've reached a point of development where more inches is better use of money than the existing available parts. Makes boost look cheap, don't it? How is boost cheap when it quickly can push well beyond what a stock block can handle?Anything in a Mopar block other than a Hemi that is over 700hp is pretty much on borrowed time. Strokers with good heads already hit 700hp easily....So adding boost is like burning the wick at both ends...These are the kinds of blocks you need for boost.
[Re: LA360]
#2670045
06/26/19 06:11 AM
06/26/19 06:11 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
I wonder if some Predator heads are going on top of it, for a Black Dart? No. I saw his new water block a few weeks ago.
[Re: polyspheric]
#2670051
06/26/19 06:34 AM
06/26/19 06:34 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
It’s a billet block. No casting. Welding is easier than the alternative which would be bolt on sealed covers. I like the china wall placement. Easy to prevent valvetrane parts from migrating into the spinny part of the engine. Also like the dual pattern bell. Nice, I bet it isn’t all that more expensive than a new priced KB.
