Re: Cam for 505 stroker
[Re: General 68]
#2670221
06/26/19 02:01 PM
06/26/19 02:01 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'm running the 23-712-9 Comp Cams Hydraulic roller cam, XR286HR10 in my 505 engine. It is 236/242 duration @ 0.050 and drives fine doing 50 MPH @ 1,500 RPM in 5th gear (Legend Gear & Transmission 700 transmission.) Engine is about 10.3:1 compression, Mild ported stealth heads, 17cc dished pistons, 1-7/8" TTI headers with 2.5" dual exhaust with X-Pipe. Originally a Performer RPM intake, but now Edelbrock XT EFI intake and FAST 2.0 EFI controller.
[Re: 451Mopar]
#2670282
06/26/19 04:04 PM
06/26/19 04:04 PM
Posts: 2,868 Pattison Texas
CSK
Pattison Texas
This is the Hyd roller 1.6 rockers I have in my 512 Charger, 3.54 gear Overdrive trans with lock up converter, I can cruise at 1800 rpm smooth with no bucking. power brake friendly?? NO
[Re: CSK]
#2670345
06/26/19 06:49 PM
06/26/19 06:49 PM
Posts: 401 Norway
General 68
Norway
Thanks! Keep it coming😄 I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs. This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp. 4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60. I have an opinion on how it will perform, but what are your opinion?
[Re: General 68]
#2670362
06/26/19 07:26 PM
06/26/19 07:26 PM
CSK
Pattison Texas
Thanks! Keep it coming😄 I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs. This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp. 4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60. I have an opinion on how it will perform, but what are your opinion? It will be a handful on the street, small cam for a 512
[Re: General 68]
#2670757
06/27/19 03:42 PM
06/27/19 03:42 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
I've been running a Hughes HE3844BL in a street-strip 400/470 E-Body, 4 spd. for 15 years. Here's the link to the cam's profile ( http://www.hughesengines.com/TechArticles/heseriescamprofilesbigblockhydraulic.php) if you like to compare with the Hughes cams you're considering. My motor has slightly more compression, E-heads, 1.6 rockers, Performer Plus intake, 1-7/8 headers with 3" exhaust, 4:10 or 3:55 gears, 3600 lbs. w/o driver, manual brakes. Low end torque is outstanding. I can lug the motor down and she pulls strong and easily to 6k. At the time, Hughes spec out the 3844 and the HE4449BL since I wanted to go with a hyd. flat tappet. With the added cubes you have, I believe you will be more than happy with the 3236.
[Re: General 68]
#2670781
06/27/19 04:44 PM
06/27/19 04:44 PM
Posts: 31,052 Oregon
AndyF
Thanks! Keep it coming😄 I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs. This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp. 4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60. I have an opinion on how it will perform, but what are your opinion? It should have a fairly smooth idle and a ton of torque down low. It will most likely run out of air by 5500 rpm but you'll be going so fast at that point that you won't care. A street car doesn't need a race cam even though a lot of people want to put race cams in street cars.
[Re: AndyF]
#2683789
08/02/19 06:19 PM
08/02/19 06:19 PM
Posts: 401 Norway
General 68
Norway
Well guys, I got the answers now🤣 Got the engine together and put in the Charger just in time to reach Orsa Dragfest in Sweden. Broke in the cam the night before we went and everything was good. Went 8.23/88.5 in the 1/8 mile. 4300lbs with med in. No prep track, Hoosier Quicktime Pro's, 28/12..5/15. Manual trans. Good vacuumn for power brakes. Engine pulled super strong. No change hooking - actually blew the tires loose when dropping the clutch at 2000 rpm. Quite scary - easy to over rew as it would fly past 6000 rpm in no time. Never got the 60' under 1,88 seconds. Broke the tires loose a bit when shifting to 2. gear. Pulled strong all the way to 6k. Won the bracket race (Had some luck😄) Idles nice and smooth at 1000 rpm. I only got time for a short test drive on travel road. Touching the go- pedal at 2000 rpm in 3rd gear would send the car sideways down the road. So far I am happy with the combo, but some carb- and chassis tuning might take it to the next level.
[Re: General 68]
#2921317
05/11/21 07:09 PM
05/11/21 07:09 PM
Posts: 3,023 NY
B1duster
NY
Thanks! Keep it coming😄 I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs. This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp. 4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60. I have an opinion on how it will perform, but what are your opinion? What octane fuel do you use ?
