Open element air cleaner on '00 Durango 5.9...
#2667538
06/19/19 12:06 PM
06/19/19 12:06 PM
Posts: 8,676 Buford, GA
I_bleed_MOPAR
Buford, GA
Been wanting to try an open element air cleaner on the Durango. I picked up a 14" air cleaner for $3 at an estate sale and bought a 14 x 3 filter for a '69 Chevelle 396 at AZ for $6. Installed it and all I can say is WOW! I had heard the factory air filter assy. was very restrictive but I can't believe the difference. I can actually feel it in my butt dyno plus I get an AVS-type wail now at full-throttle. Can't say if it will help fuel mileage since I can't keep my foot out of it. Maybe after the new wears off I can check to see if there's any improvement. Oh, and the 14" was a tight fit. Had to trim the hood weatherstrip just a little. Smaller assy. for a Durango/Dakota (12"?) might be better but probably not a problem on a Ram. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Open element air cleaner on '00 Durango 5.9...
[Re: I_bleed_MOPAR]
#2667615
06/19/19 02:39 PM
06/19/19 02:39 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Back in high school a friend had a '95 Ram w/ a 318/5.2 magnum. He put an open element K&N filter on it and I remember him saying it made a difference. Sure sounded good inside the truck too. It outran my '89 Silverado w/ a TBI 350, lol.
[Re: I_bleed_MOPAR]
#2667977
06/20/19 01:09 PM
06/20/19 01:09 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
When making a change like that it is a good idea to check the full throttle MAP and IAT sensor readings before and then after. Temperature affects the power more than pressure changes. Years ago I made a U tube manometer out of clear vinyl tubing and at full throttle and 4000 rpm on a1995 Ram Magnum 5.9 V8 measured 4 inches of water restriction ahead of the air cleaner element. This was the restriction from the passenger side fender inlet, through the corrugated plastic hose and into the air filter housing but ahead of the paper filter element. If I remember right the total restriction measured by the MAP sensor was 1.6 inches of Mercury, which converts to 21.8 inches of water. If I remember right the legendary Chrysler engineer Tom Hoover removed a headlight and by taking in air there got the inlet restriction down to zero. At 80 mph it climbed to +1 inch water. Forward facing inlets like this would clog your air filter with bugs and debris kicked up by the road traffic. Those big 18 wheel trucks that take in engine inlet air way up high get cooler air. Air near the pavement is hotter, as this I75 weather station shows. http://rwis.kytc.ky.gov/071/graph1.htm
[Re: I_bleed_MOPAR]
#2670012
06/26/19 12:26 AM
06/26/19 12:26 AM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
lol, right on buddy, you went from a factory cold air intake that pulls air from inside the fender, to a hot air intake sucking in everything it can from the exhaust manifolds. Nicely done! I actually have one 14 x 3 Edelbrock setup with the proper "J" stud and some other K and N horseschitt "hot air kit" from two Rams that I bought from Idiots over the years: free to anyone that will send Me their factory Cummins or V8 gaspot air intakes in exhange.
Mo' Farts
Moderated by "tbagger".
[Re: jerseybud]
#2670176
06/26/19 12:22 PM
06/26/19 12:22 PM
I_bleed_MOPAR
Buford, GA
Well, hey, Griz, long time, no hear from. I have read numerous places about the factory air cleaner being very restrictive and the arguments about cold air intakes vs. open air elements. Being as I had one available for less than $10, I thought I would give it a try. Very noticeable seat-of-the-pants difference but as I said, no idea about the effect on fuel mileage since the new hasn't worn off yet. If you recall, most musclecars used under hood air and did OK with it. BTW, I have a factory air cleaner assy. from my '06 2500 Cummins if you really want it. I installed a BHAF just for grins (actually picked up 1 mpg) but traded the truck for the wife's first Challenger before I could see how many miles the filter would go between changes. Tim
