Re: Electric Water Pump 35gph to 55gph?
[Re: an8sec70cuda]
#2665039
06/12/19 08:59 AM
06/12/19 08:59 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
What kind of reasoning says to get a water pump with higher flow, and then make sure you use a restrictor to slow down the flow? The water doesn't stay in the radiator longer when you have a restriction. There is always water in the radiator! It's all about the flow. A thermostat slows down the flow to make the motor run hotter. That's the only purpose for it. You only run a restriction if you want the motor to run hotter.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2665228
06/12/19 05:33 PM
06/12/19 05:33 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Joel I agree , tstat is to get up to temp quicker , can also maintain more constant . Some motors will overheat without , some with a tstat/restrictor I don't run a tstat , not keen on getting into waterbox with it closed due to cold/cool motor . Though I drove 12 hours home one winter and never saw it go to 130 My new World block is running around 15 deg warmer than both stock blocks so am following this . I have just modded a mechanical pump with plate , now to fit it . Flowcooler looks nice - but pricey . Cheaper than Edelbrock though Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2665250
06/12/19 06:36 PM
06/12/19 06:36 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
FWIW, when I set mine up for pump gas a few years back I could not get it to run under 205-210 on hot days. I already had the big mezier water pump and an alum becool radiator with dual fans. I did nothing but order a custom Ron Davis radiator with a built in shroud and dual SPAL fans. The hottest the motor would get even on the hottest days was 185 after the radiator swap. There is a BIG difference in aluminum radiators, you get what you pay for.
[Re: Bigcube]
#2665257
06/12/19 06:50 PM
06/12/19 06:50 PM
Bigcube
Upstate NY
First pic is what was in it. Worked fine when it only saw track duty. Looks very similar to yours. Second pic was the new one. It was very heavy, they use many more fins per inch than the cheap radiators.
[Re: Dragula]
#2665319
06/12/19 09:34 PM
06/12/19 09:34 PM
Bigcube
Upstate NY
Finally got a chance to take it for a 18 mile quick cruise at 8pm tonight...So nice and cool out 70 degrees , suns going down, motoring down the road at 2800rpm.....Runs about the same. Got to 190 and pretty much goes to +200 at stop signs and maybe back down to 190-195 cruising.....Basically no change, maybe worse. Left the housing from the stat in there...Should have opened up the flow a lot, but......
So I would expect it to be worse when its 87 and sunny out. Maybe find out tomorrow for cruise night if its not raining.... In my case 30 degrees water temp was worth about 10-15 PSI of oil pressure at idle. Alum block, alum rods, pressure would drop at idle if hot. Big pump and it would climb right back up with some RPM but that would make it hotter. Buy a good radiator. Back in 2013 the one I picked was for a Cuda. I changed bottom tank some and inlets and outlets to suit my car. Back then with some mods it was around $1600 but for 30 degree drop, it was worth it.
[Re: Dragula]
#2665324
06/12/19 09:49 PM
06/12/19 09:49 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My 528 aluminum Hemi has the Meziere 42gph pump, aluminum radiator and twin fans. 185-190 degrees is the highest it ever goes. The fans are set to kick on at 180 degrees. I have antifreeze and distilled water in the radiator.
[Re: Dragula]
#2665345
06/12/19 10:39 PM
06/12/19 10:39 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
So I would expect it to be worse when its 87 and sunny out. Maybe find out tomorrow for cruise night if its not raining.... Heating up at stoplights your fan(s) aren't cutting the mustard.
[Re: Dragula]
#2665346
06/12/19 10:46 PM
06/12/19 10:46 PM
ProSport
Akron, Ohio
Yeah, my aluminum Hemi never went over 190 with the system I have.....Change to Cast Iron, and presto, problemo.... Oh ok. Like these guys have mentioned, it seems that you need more fan action. Good luck with it.
[Re: STEFF]
#2665355
06/12/19 11:14 PM
06/12/19 11:14 PM
B3422W5
Portage,michigan
The faster the water flows, the more often it sees the Radiator. AGREED!!! The whole "Gut the Thermostat or run a restrictor" is BS!! A gutted out tstat like i have always run isnt much of a restriction..... at all. Its always worked excellent for me and i drive my cars But that isnt his problem, like i said in my first post in this thread. His fans aren't up to snuff. He just reported it heats up at stoplights, classic symptom of not enough cooling fan..... or low amount of water in the system which i doubt the OP hasnt looked at. I ran with no tstat years ago, i like and prefer the very small restriction the gutted deal gives me. Car gets away from being cold a little quicker. Real cold isnt real good. Not a big difference, but there is some. Have tried normal tstat( 160 and 180) normal tstat with couple of small holes drilled. None.... and gutted I like how i currently have it. Closest to the best for both street and strip
[Re: B3422W5]
#2665587
06/13/19 06:10 PM
06/13/19 06:10 PM
Posts: 12,401 Taxes & Virus's R-US, NY
Dragula
So I would expect it to be worse when its 87 and sunny out. Maybe find out tomorrow for cruise night if its not raining.... Heating up at stoplights your fan(s) aren't cutting the mustard. That is what this little experiment seems to be telling me. But I want to try one more thing first. So the weather is not cooperating, as it is cold and rainy here, and looks likely to be right thru till Sunday, I guess we will see. So my next step is to take the hollowed out t-stat out, and go on a similar 10-20 mile cruise with no restrictor at all and see if the results are the same....Data says very likely, and I need to replace my 1995 dual 12" 2500cfm Flex-a-lite fans with a set of BeCool fans. I run a BeCool 62087 rad and its been great....But I seem to have hit a point where I am having trouble. I was originally thinking I needed to go with a bigger water pump, but removing all that restriction seems to be sending me in the other direction. l called BeCool just the other day, and they seem to agree, the fans are the issue and recommended their 75638 .. 3560cfm 13" dual fan unit.
[Re: Dragula]
#2665676
06/13/19 10:40 PM
06/13/19 10:40 PM
B3422W5
Portage,michigan
Not sure what that be cool fan setup costs But before you pull the trigger on that take a look at the 4000cfm Derale dual fan setup. They are American made and work impressively. The rep at Motor state i buy my stuff from went to the Derale factory. He prefers them over any other fan out there. They move air
[Re: B3422W5]
#2665720
06/14/19 07:26 AM
06/14/19 07:26 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If you are really wanting to spend some money on fans look at Delta Pag. Lightweight, variable speed, high volume. The price considering it comes with a controller isn't so horrible. There is several drag week guys who run them including the last two years winners. They seem to be able to cool 6 second cars OK.
68 Barracuda Formula S 340
[Re: Clanton]
#2667001
06/17/19 08:19 PM
06/17/19 08:19 PM
Dragula
Do you think taking some fuel out or adding timing would help?Will you try it eventually? GO LEANER? ....That would be no. Its at 14.0-15.0 cruising depending on current conditions. Today she was at 14.2 while cruising and 13.0-13.5 at idle. Timing...Well big motors do not like a lot of timing, and I tried this two ways. One with an MSD distributor setup the way we race with about 15-18 timing at idle and 31-32 total. Same results... Then I went back to my Firecore with the mechanical closed down a bunch....This runs with 22-23 idle timing and 31-32 total....Car idles a whole lot better with this setup....So this is what I am using. I could go to 34 as it really seems to like that for street...But didn't try it up that high. I did back to back runs of the same trip with each distrubutor, and I had the same results....For racing we set the timing down to 29-30.....
