Bent Torsion Bar Adjusting Bolt #2665306
06/12/19 08:59 PM
06/12/19 08:59 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
So I finally got one torsion bar in and tightened the adjuster bolt, but decided to back it out just to make sure I counted the turns right. For some reason it was near impossible to turn it counterclockwise at all. After turning it maybe 1 turn in 10 minutes I gave up and realized the bolt bent while trying to loosen it.
1. Why was it so damn hard to loosen it, is there something I didn’t think about?
2. What’s the best way to get this bolt out without damaging anything else?
Re: Bent Torsion Bar Adjusting Bolt [Re: 70charger512] #2665314
06/12/19 09:17 PM
06/12/19 09:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The best idea is to take all the weight off the front suspension before twisting the adjustment bolts.
Re: Bent Torsion Bar Adjusting Bolt [Re: 70charger512] #2665453
06/13/19 10:43 AM
06/13/19 10:43 AM
moparx Offline
moparx  Offline
did you use any lube on the threads when you installed the adjuster bolts ?
if the bolt is bent, the only fix is to cut the bolt off next to the block, then replace both pieces.
it sounds like the threads are galled on both.
you "may" be able to heat the block enough to get the bolt to screw out, but they both need replaced just the same.
beer
Re: Bent Torsion Bar Adjusting Bolt [Re: moparx] #2665472
06/13/19 11:39 AM
06/13/19 11:39 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
This...
Don't adjust the bolts with weight on the suspension.
Re: Bent Torsion Bar Adjusting Bolt [Re: burdar] #2665599
06/13/19 06:48 PM
06/13/19 06:48 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
I did have the weight off of the suspension. I installed the torsion bar and tried adjusting it right after. I tightened and loosened it once and the second time I got OCD and tried to loosen it again to make sure I knew exactly how many turns I made. When I tried backing it out it wouldn’t come out and me cranking on it caused it to bend.
Re: Bent Torsion Bar Adjusting Bolt [Re: 70charger512] #2665685
06/13/19 11:46 PM
06/13/19 11:46 PM
AndyF Offline
AndyF  Offline
Those bolts carry a lot of load so you have to coat them with ARP lube or high pressure grease. Adjust them with the weight off the suspension and you should be good to go.
Re: Bent Torsion Bar Adjusting Bolt [Re: AndyF] #2669029
06/23/19 01:29 PM
06/23/19 01:29 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Re: Bent Torsion Bar Adjusting Bolt [Re: 70charger512] #2669046
06/23/19 02:53 PM
06/23/19 02:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Be sure you have the weight off that suspension because the torsion bar will still have some pressure on it. Have you got a saws all?
Re: Bent Torsion Bar Adjusting Bolt [Re: 70charger512] #2669085
06/23/19 05:08 PM
06/23/19 05:08 PM
AndyF Offline
AndyF  Offline
[quote=]I used just WD40 on the drivers side, but didnt even attempt to double check the turns in case this happens again. But what does everyone suggest I do about the current screwed up bolt? Right now im attempting to cut the sides of the block, and hope to slide the whole thing straight down, but using a dremel takes awhile. Any ideas? [/quote]
If it was my car I'd pull the LCA out of there. It only takes about 30 minutes if you have the right tools. Get the car up in the air, knock the torsion bar out, disconnect the two bolt to the knuckle, unbolt the strut, remove the LCA pin nut and knock the whole thing out of the there. Then you can take the LCA to a shop and have them cut the old bolt and mount out of there. Shouldn't take too long with a saw or a torch.
