Old enclosed trailer- how to remove "chalk" from white panel #2663949
06/09/19 08:44 AM
06/09/19 08:44 AM
gregsdart Offline OP
My tailer is showing its age. I bought it in 1998. White exterior is dull and chalky, and tough to get off. What have you found is a good way to remove the chalk?
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2663961
06/09/19 09:19 AM
06/09/19 09:19 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A good wash then a wax job usually does the trick.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2663968
06/09/19 09:54 AM
06/09/19 09:54 AM
pa
gregcharger72 Offline
pa
i used simple green and water , make the mix strong use a quart to four gallons of water. then use a cleaner wax with a buffer using a wool pad . that process would last a season before i needed to do it again. usually took a full day to do.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregcharger72] #2663970
06/09/19 09:58 AM
06/09/19 09:58 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
Awesome cleaner from dollar general. Will take off the black streaks also.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: NoFrills] #2664034
06/09/19 01:52 PM
06/09/19 01:52 PM
iagree scope up
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: Cab_Burge] #2664099
06/09/19 05:23 PM
06/09/19 05:23 PM
Thanks, gentlemen!!
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2664109
06/09/19 06:23 PM
06/09/19 06:23 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
Trisodium phosphate. Years ago we used trisodium phosphate on big water tanks and towers to remove the old chalking paint before repainting. We cut up floor buffing pads and dipped then in the trisodium/water solution, white or grey scotchbrite pads might work.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: angleiron2] #2664138
06/09/19 07:43 PM
06/09/19 07:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The "chalk" is oxidation; as the paint essentially dries out from exposure, the pigment basically rises to the surface.
Back in the days of nitrocellulose lacquer and the early enamels, you'd polish that off with a compound.
Problem with the trailer panels is most don't have a very thick coating, so you want to take it easy.
An aggressive rubbing out can remove 1 to 1.5 mils, and there may only be 4-5 mils applied.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: topside] #2664160
06/09/19 08:47 PM
06/09/19 08:47 PM
East Coast
A/MP Online content
A/MP  Online Content
East Coast
Short term-wash-n-wax. Long term-sand down to bare metal or close to that. Use a Sherwin Willians industrial enamel and it will be good for 7-10 years. You can also use a siliconized oil based paint( reasonable price compares to 1K or 2K). High gloss and long gloss retention. Very durable. You need to spray or roll it in a garage. Takes 8-10 hours to set.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: Cab_Burge] #2664167
06/09/19 09:17 PM
06/09/19 09:17 PM
iagree scope up
Correction on the name, it is labeled as "LA totally AWESOME" cleaner on the bottles, it is piss yellow color also blush
It sure does work well on my white car trailer up
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: Cab_Burge] #2664169
06/09/19 09:22 PM
06/09/19 09:22 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
Rejuvenator made by Malco works awesome
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2664175
06/09/19 09:51 PM
06/09/19 09:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That’s the trade it off signal!
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: J_BODY] #2664197
06/09/19 10:51 PM
06/09/19 10:51 PM
What, trade off a low mileage one owner?
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2664468
06/10/19 04:59 PM
06/10/19 04:59 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
I used lemon pledge after a basic wash and it brought back the shine and no more "chalk" when I wipe my hand across it. I've been doing that for 4 years now and seems to be working like a charm. as a side note, I live in Alaska so our weather conditions are different and I don't use it as much as most of you guys. just try it on a small area see for yourself.
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: 9secondsatellite] #2664498
06/10/19 06:29 PM
06/10/19 06:29 PM
I use to use Lemon Pledge on my airplane windows also up
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2664506
06/10/19 06:50 PM
06/10/19 06:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I will try to remember the name of the floor wax that Lowes sells that guys use on their trailers. There was a big post on Yellowbullet about it
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: pittsburghracer] #2665268
06/12/19 07:20 PM
06/12/19 07:20 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
Totally Awesome for sure, cheap and effective, just dont leave it on for too long, rinse quickly!
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
Re: Old enclosed trailer- how to remove "chalk" from white panel [Re: gregsdart] #2665335
06/12/19 10:13 PM
06/12/19 10:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2..... I use the dollar general stuff.
Wash with car wash soap and brush, rinse, destreak, rinse, squeegee one panel at a time, dry, hit with McGuires and buffer. It’s a hard game to play in the desert. I’ll never buy a top shelf trailer unless I have a garage to put it in.
