alternator mounting bracket bolt/washer #266362
03/25/09 08:08 PM
03/25/09 08:08 PM
California
70SportSatellite Offline OP
super street
super street
California
Hi,
I'm using a Moparr Motors Detroit bolt guide and it states that the lower alternator mounting bracket bolt always uses a washer. Page 203. On page 233 is a drawing showing no washer but shows one on the upper bolt that passes through the spacers. Can I get some clarification? Is it an A/C non A/C difference. Thanks
Re: alternator mounting bracket bolt/washer [Re: 70SportSatellite] #266363
03/25/09 09:06 PM
03/25/09 09:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's a captive washer bolt
Re: alternator mounting bracket bolt/washer [Re: gtx6970] #266364
03/25/09 09:24 PM
03/25/09 09:24 PM
California
super street
super street
California
Hi Bill,
The bolt I'm referring to is not the adjustment bolt for the belt tension but the lower bolt that passes through the slotted bracket and the triangular bracket securing it to the engine. Again, the book says washer but the drawing says no, drawing shows washer on the bolt that goes through the heater hose bracket, triangular braket and alt. spacers. Thanks again.
Re: alternator mounting bracket bolt/washer [Re: 70SportSatellite] #266365
03/25/09 10:23 PM
03/25/09 10:23 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Maybe this will help.
Re: alternator mounting bracket bolt/washer [Re: Snoopy] #266366
03/26/09 10:32 AM
03/26/09 10:32 AM
California
super street
super street
California
here is the drawing I have. you can see the washer at the upper bolt.
Re: alternator mounting bracket bolt/washer [Re: 70SportSatellite] #266367
03/26/09 10:35 AM
03/26/09 10:35 AM
California
super street
super street
California
here is the page from the book saying the lower ALWAYS uses a washer which seems to contradict the drawing.
