Re: Fuel Injection
[Re: a12rag]
#2663028
06/06/19 12:02 PM
06/06/19 12:02 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
A buddy just had the ProFlo4 installed on his 440 powered 69 Coronet. It's been an amazing set-up for him so far, and is performing flawlessly since install a few months ago.
A well thought out fuel system that matches your performance goals is mandatory for both performance and safety.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Fuel Injection
[Re: jbc426]
#2663068
06/06/19 01:11 PM
06/06/19 01:11 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Lots of options out there, I like the Megasquirt stuff, it has the best feature to dollar ratio, but it does take a little more work to install. I have almost 5 years on a DIYAutotune MS3X kit that I assembled myself with sequential fuel and spark, coil on plug igntion on my small block. It has been a real good experience but I like to really dig into stuff, it was far from bolt together and race.
If I were to be in the market for one of the throttle body units Holley would get my business hands down.
68 Barracuda Formula S 340
Re: Fuel Injection
[Re: a12rag]
#2663270
06/06/19 09:24 PM
06/06/19 09:24 PM
Bad340fish
Tulsa OK
Holley all the way, they even have a kit that looks a whole lot like a carb. I think it is the terminator throttle body? The name escapes me right now.
Re: Fuel Injection
[Re: BDW]
#2663429
06/07/19 11:04 AM
06/07/19 11:04 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I did FiTech for my install and it was an easy installation and has been running flawlessly. I understand the FiTech is “self- learning” with a wide band O2 sensor. Can the owner custom set the air to fuel ratio, or is it set at something like 12.7 or 14.7 at the factory and not owner adjustable?
Re: Fuel Injection
[Re: 360view]
#2663431
06/07/19 11:08 AM
06/07/19 11:08 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
AFR is completely adjustable, within some limit though.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Fuel Injection
[Re: Bad340fish]
#2663432
06/07/19 11:12 AM
06/07/19 11:12 AM
Posts: 8,162 USA
360view
USA
Lots of options out there, I like the Megasquirt stuff, it has the best feature to dollar ratio, but it does take a little more work to install. I have almost 5 years on a DIYAutotune MS3X kit that I assembled myself with sequential fuel and spark, coil on plug igntion on my small block. Can the MS3X do cylinder by cylinder variation on fuel and spark? I mean can Number 1 cylinder be set to standard fuel injector on time and spark, but Number 8 cylinder varied to plus 10% more milliseconds of fuel injector on time and Number 8 spark to 2 degrees of retard?
Re: Fuel Injection
[Re: 360view]
#2663438
06/07/19 11:22 AM
06/07/19 11:22 AM
Bad340fish
Tulsa OK
Yes, you can fuel and time each cylinder differently if you are setup for sequential. Sequential requires a cam sensor. I use a Jeep 4.0 cam sensor with an adapter from SD concepts and Andy F's awesome Billet 36-1 trigger wheel.
You have your base fuel table and timing tables, from there you can add or subtract a % of fuel from each cylinder. I have not messed with per cylinder timing but I assume it works the same way.
MS3X can even run closed loop per cylinder if you happen to have 8 02 sensors.
Re: Fuel Injection
[Re: a12rag]
#2663587
06/07/19 06:18 PM
06/07/19 06:18 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I used a 93 Magnum and converted it to OBD2 so it can be tuned for a cam, headers and possibly an intake and heads later. It is also good for forced induction too.
Re: Fuel Injection
[Re: a12rag]
#2663600
06/07/19 07:06 PM
06/07/19 07:06 PM
Posts: 31,050 Oregon
AndyF
I helped dyno tune a 408 with Trick Flow heads and a Holley Sniper yesterday. The engine was super sweet with a nice smooth idle and almost 500 ft-lbs of torque. It is going in an A body car so it should really scoot. The owner had gone with the full Holley setup including the EFI distributor and ignition. He'll be able to tune the car with his laptop as he drives down the freeway.
Re: Fuel Injection
[Re: a12rag]
#2663672
06/08/19 12:13 AM
06/08/19 12:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The new Sniper and FiTech TBI EFI are really good for the money. Way better than the old non-wideband O2, non-self learning systems that were way more expensive. I did the old Edelbrock XT EFI several years back and it was OK, but the old style computer did not offer any additional options. I upgraded the electronics of it with a FAST 2.0 computer system, but I have way too much money into that system. Just for fun, I put a FiTech 1200 pa on the 500" Charger engine with 12.4:1 compression, and a large 270+ duration @ 0.050", 0.700"+ lift cam just because everyone said you can't use EFI on a engine with a big cam. It actually runs really good. I may have gave up a bit of power because the EFI throttle body is only around 800 cfm, and I was running a 1,000 cfm HP Carb before, but the EFI drivability it so much better I don't want to go back to a carb.
Re: Fuel Injection
[Re: 451Mopar]
#2663711
06/08/19 07:36 AM
06/08/19 07:36 AM
Bad340fish
Tulsa OK
You can probably get away with fitech on that engine because of the big cubic inches. That is a big cam for a 360 but IMO way less radical with 500 inches. There is a certain range of vacuum signal that a preprogrammed unit like fitech will be able to work with, once you find your way outside of that range you will wish you had something with a more programable fuel map.
