Re: Anybody hook up Dakota wiper control to old one-speed wiper
[Re: Old Ray]
#2662968
06/06/19 09:10 AM
06/06/19 09:10 AM
Posts: 19,641 north of coder
moparx
i don't think it would be difficult to hook the old one speed motor up to to the dak switch, but the intermittent feature is run through the body control module. i would have to study the wiring schematics and read up on the diagnostics to see if that could be possible. if going to that trouble for only a single speed, i think i would adapt the complete dak wiper system as well. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2663123
06/06/19 04:01 PM
06/06/19 04:01 PM
Posts: 6,330 nowhere
Sniper
nowhere
Here a DIY Kit that might be the ticket.
[Re: poorboy]
#2703195
10/02/19 08:33 PM
10/02/19 08:33 PM
Posts: 240 British Columbia, Canada
Old Ray
Really small useless update. Change of plans, the 1992 Dakota wiper motor is almost a bolt into the '56 bracket. Not wired into the Dakota wiring harness / steering column yet so not sure if its going to work. Now, if I could figure out,at age 75, how to get back up and out after lying upside down under the dash ![help help](/ubbthreads/images/graemlins/custom/smilie_help.gif)
[Re: Old Ray]
#2703215
10/02/19 09:14 PM
10/02/19 09:14 PM
Posts: 10,651 Freeport IL USA
poorboy
Freeport IL USA
Really small useless update. Change of plans, the 1992 Dakota wiper motor is almost a bolt into the '56 bracket. Not wired into the Dakota wiring harness / steering column yet so not sure if its going to work. Now, if I could figure out,at age 75, how to get back up and out after lying upside down under the dash I just turned 63, getting out from under the dash is very difficult for me already, I'm afraid by the time I get to 75 (if I make it that far), even considering getting under the dash would probably be a deal breaker. I paid someone to change the heater core in my 96 Dakota a couple weeks ago because I didn't want to have to remove the dash. Years past, I wired up an old 2 speed wiper motor with an off-on-off switch. one on was low speed, the other on was high speed. The problem was when you turned it off, the wipers stop immediately, they would not park. It took some practice, but I got pretty good at having them stop at the end of the stroke. A Dakota has 4 wires to the motor, the motor grounds through the switch. One wire is power in, one is low speed to the switch, one is high speed to the switch, and the last one is for park position (I think its momentary power after the switch is shut off) but I don't have the book with me right now. Gene
