Re: Octane Adders Klotz
[Re: sogtx]
#2662000
06/03/19 08:54 PM
06/03/19 08:54 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I used klotz octane booster on drag week. I bought race fuel at the track each day, but for the street Drive I used 93 octane pump gas with some Klots in it. I didn't drive it hard on the street, but I didn't want to have any issues. It worked fine in my 13.5 to 1 Hemi. I never heard it rattle once. Use a metal or glass measuring cup. It melted the plastic one. https://www.summitracing.com/parts/...I_83O4gIVx7XACh1jLwX3EAQYASABEgJwPfD_BwE
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2662043
06/03/19 10:18 PM
06/03/19 10:18 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I used klotz octane booster on drag week. I bought race fuel at the track each day, but for the street Drive I used 93 octane pump gas with some Klots in it. I didn't drive it hard on the street, but I didn't want to have any issues. It worked fine in my 13.5 to 1 Hemi. I never heard it rattle once. Use a metal or glass measuring cup. It melted the plastic one. https://www.summitracing.com/parts/...I_83O4gIVx7XACh1jLwX3EAQYASABEgJwPfD_BwE Probably uses acetone as the active ingredient. Most of them are mostly toluene or acetone. Google around and you can find a few recipes. Toluene is cheaper by the gallon than by the 16 oz can. Kevin
[Re: Twostick]
#2662460
06/05/19 01:36 AM
06/05/19 01:36 AM
Posts: 109 Cottage Grove OR
WFO
Cottage Grove OR
I used klotz octane booster on drag week. I bought race fuel at the track each day, but for the street Drive I used 93 octane pump gas with some Klots in it. I didn't drive it hard on the street, but I didn't want to have any issues. It worked fine in my 13.5 to 1 Hemi. I never heard it rattle once. Use a metal or glass measuring cup. It melted the plastic one. https://www.summitracing.com/parts/...I_83O4gIVx7XACh1jLwX3EAQYASABEgJwPfD_BwE Probably uses acetone as the active ingredient. Most of them are mostly toluene or acetone. Google around and you can find a few recipes. Toluene is cheaper by the gallon than by the 16 oz can. Kevin Yeah toluene and xylene are both legit octane boosters, but you have to mix a decent amount of them to get a real boost. They used to be the hot trick on the Turbo Buicks before the advent of methanol injection. A gallon of xylene, a cap of marvel mystery oil and 9 gallons of premium would keep the knock monsters at bay.
'65 Plymouth Sport Fury Blow thru twin turbo coming soon...
[Re: Twostick]
#2662756
06/05/19 06:16 PM
06/05/19 06:16 PM
Hemi_Joel
Minnesota
I used klotz octane booster on drag week. I bought race fuel at the track each day, but for the street Drive I used 93 octane pump gas with some Klots in it. I didn't drive it hard on the street, but I didn't want to have any issues. It worked fine in my 13.5 to 1 Hemi. I never heard it rattle once. Use a metal or glass measuring cup. It melted the plastic one. https://www.summitracing.com/parts/...I_83O4gIVx7XACh1jLwX3EAQYASABEgJwPfD_BwE Probably uses acetone as the active ingredient. Most of them are mostly toluene or acetone. Google around and you can find a few recipes. Toluene is cheaper by the gallon than by the 16 oz can. Kevin Guy would doubt that it uses acetone as an active ingredient. Because you only have to put in about a cup for a 15 gallon tank. If it was acetone I think you'd have to put in a lot more
