I have a '71 Satellite with 440, power steering, tti headers and a mini-starter. I've not removed either the headers or the starter with the motor already in the car, but before installing the motor, I found that I had to put both the header and the starter on together. That is, because of the steering box, neither would go on with the other already in place. You'll have to unbolt the header from both the head and at the collector, unbolt the starter, swing the header out at the bottom and maneuver the starter out straight down. You may also have to come up from underneath to get at the nuts/bolts. Good luck.
