3600-3700 lbs car to run 9.50's? #266160
03/25/09 03:57 PM
03/25/09 03:57 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
What does it take to run 9.50-9.60's range with a car in the 3600-3700 lbs? Couple of buddies was wondering what E/T expectations I have for the car. Surly this Hemi will squeeze out 750HP.
-572 inch
-12.5:1 compression
-MP Cross Ram
-CNC ported Hemi heads flow 458CFM+
-Solid flat tappet with .700 lift and 280+ dur @50
Loose converter, 4.88 Dana gears, leaf springs, and cal tracks. 14x32 slicks.
What a ya think?
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266161
03/25/09 04:08 PM
03/25/09 04:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
About 850 to get 9.50
Re: 3600-3700 lbs car to run 9.50's? [Re: MR_P_BODY] #266162
03/25/09 04:27 PM
03/25/09 04:27 PM
Rock Springs
Rock Springs
Mr-P
I just don't think this engine will make 850, it might make on the high side of 750+ But, I have little Hemi experience. I know what it takes to make 850 and this one doesn't have it....
If it had a solid roller, and sheet metal intake, like off a SS car. I know it would make 50-75+HP over the configuration I will be running at first..
But I have been known to get serious with engines in the past. Never bothered me to take one apart for no real apparent reason.
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266163
03/25/09 04:47 PM
03/25/09 04:47 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
You should easily run 9.50s w/ that combo. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266164
03/25/09 04:59 PM
03/25/09 04:59 PM
Mr-P
MY LAST HEMI BUILD WAS VERY CLOSE TO THAT AND YOUR HEADS FLOWED WAY MORE THAN MINE.581 CI 11.8 compression MP aluminum heads flowed 378 cfm with a .750 roller cam made 812 hp with mp hemi crossram. the head porting was horrible.
i switched out the heads for the indy hemi heads and will find out shortly what this new combo should make.
i think your heads will help you alot and you will be surprised on your power.
going 9.50's i think you will be just shy of that.
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266165
03/25/09 05:13 PM
03/25/09 05:13 PM
Mine is 11:1 compression for pump gas, heads flow 430 cfm on the intake, cam is a roller but with similar duration (mild grind for street durability), and a single dominator on the Barton cast manifold. Performance in my sig. CHIP
CHIP
Re: 3600-3700 lbs car to run 9.50's? [Re: an8sec70cuda] #266166
03/25/09 07:30 PM
03/25/09 07:30 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
The last NSS 572 I built was 12 to 1 comp., solid roller, MP crossram, 110M alum heads that flow 400, made 925HP, 740 TQ
Be a Rebel- Break the Laws of Physics!
Re: 3600-3700 lbs car to run 9.50's? [Re: mbogina] #266167
03/25/09 08:50 PM
03/25/09 08:50 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
512CI 13.9 to 1. Pump Gas............pumped it right out of a 5 gallon jug.
T-400 Trans, Dana 60, 10.5" Tires on Leaf Springs
1.36 60' --- 9.55 @ 142 mph 3640#
Re: 3600-3700 lbs car to run 9.50's? [Re: Bubba] #266168
03/26/09 08:15 AM
03/26/09 08:15 AM
pa
572charger Offline
572charger  Offline
pa
my 11.7 to one 606 cube hemi stage v heads flow 449 at 700 lift comp cams 282/290 720/690 lift single carb raybarton intake prosystems carb 1220 cfm in my 3885 lb car has gone 9.60 at 141.75 with a 31 inch et street caltracks 1.39 60ft on pumpgas with full exhaust !! only has a 4.30 gear ! i race it like i drive it !!! with more carb i think it will go 9.40s !! we will see soon !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266169
03/26/09 08:21 AM
03/26/09 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think a big single Dominator carb might work better. I think you can mke the ppower but keeping everything together at launch w/ a car that heavy might be a problem. I'd spend some time and money in your drive line parts.
Re: 3600-3700 lbs car to run 9.50's? [Re: Mr.Yuck] #266170
03/26/09 08:33 AM
03/26/09 08:33 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
WOW, You guys got lotsa Cubes and killer head flow numbers. I'ld figure most of you Hemi guys would be laying down some seriously LOW 9's..
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266171
03/26/09 09:37 AM
03/26/09 09:37 AM
-572 inch
-12.5:1 compression
-MP Cross Ram
What a ya think?
I have a simple question for ya:
Why the heck run a flat tappet cam? You got all that money tied up in a killer Hemi, and you gonna run a $50 camshaft?
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266172
03/26/09 09:43 AM
03/26/09 09:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With 572ci you should be able to make 850 hp easy,
thats only 1.5 hp per ci..... anyone can make that
Re: 3600-3700 lbs car to run 9.50's? [Re: Bubba] #266173
03/26/09 10:22 AM
03/26/09 10:22 AM
Mine as well as 572charger's motors are low compression and are on the tame side as far as camshafts and such to maintain streetability. With a more race oriented setup they would be running much faster. I know I made quite a bit of compromises with my build to keep it street friendly. CHIP
CHIP
Re: 3600-3700 lbs car to run 9.50's? [Re: an8sec70cuda] #266174
03/26/09 11:05 AM
03/26/09 11:05 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
I understand Chip, I was just looking at the numbers.
Jim's Charger for example:
Hemi / Wedge
HIS 3885# Mine 3640# = 245#
COMP 11.7 - 13.9 = 2.2p
Cams Pretty darn close.
Heads 449 - 366 = 83CFM
CID 606 - 512 = 94CI
Gears 4.88 - 4.10
suspension Pretty much the same.
Tires ??? - 10.5"
ET 9.60 - 9.55
2 Points of Compression and a Diet and his hemi is in the 8's ?????
or take away 94Cubes and 83 CFM and he could be in the 9.XX's ??????
I'm confused now... What was your setup?
Re: 3600-3700 lbs car to run 9.50's? [Re: Bubba] #266175
03/26/09 11:23 AM
03/26/09 11:23 AM
Hemi / Wedge
Gears 4.88 - 4.10
Tires ??? - 10.5"
ET 9.60 - 9.55
Mine---yours
3800---3640 = 160#
11:1---13.9:1 = 2.9 points
276/284 at fifty, .672"/.651" lift, mild ramps and lift so not a lot of spring pressure...don't know your cam specs
heads 430 cfm---366 cfm = 64 cfm
cid 572---512 = 60 cid
gears 4.10---4.10
suspension...cal-tracs---???
tires...295 radials---???
ET 9.54---9.55
With 3 more points of compression, a more aggressive camshaft, and a race only converter... I'm sure I'd be a lot faster than I am right now. But then I'd be on race fuel and the valvetrain wouldn't take the abuse of constant street driving without costly maintenance.
I don't really care how much faster it'd be with those changes b/c that's never what I intended to do with it. Like it sits I can drive it to the track, click off mid 9s without changing a thing, and then drive it home. Stop and fill up w/ pump 93 on the way back. CHIP
CHIP
Re: 3600-3700 lbs car to run 9.50's? [Re: an8sec70cuda] #266176
03/26/09 01:46 PM
03/26/09 01:46 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Got it!
Re: 3600-3700 lbs car to run 9.50's? #266177
03/26/09 05:16 PM
03/26/09 05:16 PM
Rock Springs
Rock Springs
-572 inch
-12.5:1 compression
-MP Cross Ram
What a ya think?
This car will see lots, and lots of street use...
Im not worried about the cams performance...
I wish the cam and lifters were only $50, I would have saved about $350 then. LOL
I also know what happens when you loose a roller lifter, despite what people say...they can and will come apart. Most people keep this from happening, by replacing them ever few seasons.
I really like a solid flat tappet cam, period. They are simple, and dont fly apart on you. With the cam specs I am looking at with this solid flat cam, the spring pressures would be pretty high with the same size roller. I don't waste my money of Hyd roller crap. Two cam choices for me, large solid flat cam, or larger solid roller. Go big or stay home, no in between..
Cam is a Custom Bullet from Ray Barton. Ray has quite a bit of experience with cam testing in Hemi's. He wouldn't even tell me the spec's, until I payed for it LOL Other than "Its a Big One"
cam has .700+ lift, and dur @ 50 is 282.... Hows that for you little roller guys
Lifters are Howards EDM direct lube style.
It will eventually get a roller upgrade BTW, but not until it comes off the street.
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266178
03/27/09 02:24 PM
03/27/09 02:24 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
This thread is starting to worry me.
It's a good possibility FHO is building me more than I can chew.
Guess I'll have to wait and see.
Re: 3600-3700 lbs car to run 9.50's? [Re: The Shadow] #266179
03/27/09 02:34 PM
03/27/09 02:34 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
With a 3/4 race cam, not an issue. Hey Mark John has his 'roid on the dyno here locally today, when I get some hp numbers I'll let you know.
steve
Photobucket sucks
