RPM activated retard w/MSD6al #2661308
06/01/19 07:13 PM
06/01/19 07:13 PM
Az
HOT IN AZ Offline OP
Az
I'm trying to get the components to hook up a rpm activated switch to retard my timing on a naturally aspirated 340.I talked to MSD and they suggested a 8987 which I don't see any rpm activation. I think what I need is a 8950 switch with a 8676 retard but I'm not sure if they are compatible. May need to talk with them some more. Any suggestions? Thanks in advance.
Re: RPM activated retard w/MSD6al [Re: HOT IN AZ] #2661419
06/02/19 07:49 AM
06/02/19 07:49 AM
HR3128 Offline
HR3128  Offline
Check out MSD 8970 - 3 step timing retard. with 8950 RPM switch.
https://www.jegs.com/InstallationInstructions/100/121/121-8970.pdf
Figure 11 on page 6 shows rpm switch connection to the 8970.
Re: RPM activated retard w/MSD6al [Re: HR3128] #2661532
06/02/19 01:08 PM
06/02/19 01:08 PM
Penna
70satelliteguy Offline
Penna
The 8970 is a good unit both for start retard as well as retarding for Nitrous.
Mike
Re: RPM activated retard w/MSD6al [Re: 70satelliteguy] #2661932
06/03/19 05:42 PM
06/03/19 05:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Not sure what the"upgrades" will cost,but the MSD 6al-2 is laptop programmable.You make your own curve with ability to change timing every 100 rpm.
https://www.holley.com/products/ignition/ignition_boxes/street_and_strip/parts/6530
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: RPM activated retard w/MSD6al [Re: hemi-itis] #2662093
06/04/19 05:38 AM
06/04/19 05:38 AM
HR3128 Offline
HR3128  Offline
looks like this one would work. MSD 8987.Start & one step retard.
https://documents.holley.com/8987.pdf
