External Balanced ? #2661158
06/01/19 10:37 AM
06/01/19 10:37 AM
S.E. WI
RichL1967 Offline OP
S.E. WI
Hey all,
Can you tell by just this picture if this 1973 truck 440 is Internal or External balanced?
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: External Balanced ? [Re: RichL1967] #2661195
06/01/19 12:17 PM
06/01/19 12:17 PM
I've seen a 400 truck stick shift motor(1976 3/4 ton pick up) with the thin balancer like yours that had a bunch of holes drilled on the back side of them for external balanced motors, that motor had a forged steel crankshaft in it also confused shruggy
I would pull the dampener to see if it has a bunch of holes drilled in it also scope If so count on the motor being external balanced twocents
That motor may have the big wide six pack type rods in it also scope If so sell them heavy rascals and buy some good forged steel H or I beam rods up
Re: External Balanced ? [Re: RichL1967] #2661251
06/01/19 03:52 PM
06/01/19 03:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '73 truck was most likely a forged crank and internal balance. I believe any drilled holes are for mass balance, external balance is by the eccentric on the inner hub.
Re: External Balanced ? [Re: John_Kunkel] #2661285
06/01/19 05:58 PM
06/01/19 05:58 PM
God's Country Maryland
GODSCOUNTRY340 Offline
All I know is that balancer is for an internal balanced engine.
Re: External Balanced ? [Re: GODSCOUNTRY340] #2661839
06/03/19 12:32 PM
06/03/19 12:32 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: External Balanced ? [Re: an8sec70cuda] #2661912
06/03/19 04:50 PM
06/03/19 04:50 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Balancer Info This is pertinent to your question but I agree with the others, looks like an internal balancer to me.
Re: External Balanced ? [Re: 6PakBee] #2662008
06/03/19 09:03 PM
06/03/19 09:03 PM
Near Columbus, Ohio
++MAX WEDGE++ Offline
Near Columbus, Ohio
internal, forged crank.
