External Balanced ?
#2661158
06/01/19 10:37 AM
06/01/19 10:37 AM
Posts: 101 S.E. WI
RichL1967
S.E. WI
Hey all,
Can you tell by just this picture if this 1973 truck 440 is Internal or External balanced?
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: External Balanced ?
[Re: RichL1967]
#2661195
06/01/19 12:17 PM
06/01/19 12:17 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I've seen a 400 truck stick shift motor(1976 3/4 ton pick up) with the thin balancer like yours that had a bunch of holes drilled on the back side of them for external balanced motors, that motor had a forged steel crankshaft in it also I would pull the dampener to see if it has a bunch of holes drilled in it also If so count on the motor being external balanced That motor may have the big wide six pack type rods in it also If so sell them heavy rascals and buy some good forged steel H or I beam rods
[Re: RichL1967]
#2661251
06/01/19 03:52 PM
06/01/19 03:52 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A '73 truck was most likely a forged crank and internal balance. I believe any drilled holes are for mass balance, external balance is by the eccentric on the inner hub.
[Re: GODSCOUNTRY340]
#2661839
06/03/19 12:32 PM
06/03/19 12:32 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
All I know is that balancer is for an internal balanced engine.
[Re: an8sec70cuda]
#2661912
06/03/19 04:50 PM
06/03/19 04:50 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Balancer Info This is pertinent to your question but I agree with the others, looks like an internal balancer to me.
