HOW TO TELL IF ITS A 440 6-PACK BLOCK #266097
03/25/09 02:31 PM
03/25/09 02:31 PM
Anonymous OP
Anonymous OP
How can you tell if a block is from a 440 6-pack motor?
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266098
03/25/09 02:32 PM
03/25/09 02:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With a VIN from a known LEGIT 440 - 6 pack car .
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266099
03/25/09 02:43 PM
03/25/09 02:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I posted it first this time
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: ScottSmith_Harms] #266100
03/25/09 03:16 PM
03/25/09 03:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Without the rest of the engine parts it's just a 440 block.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266101
03/25/09 03:43 PM
03/25/09 03:43 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Stating some obvious stuff:
If its original paint is turquoise or light blue, it's not...
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266102
03/25/09 03:45 PM
03/25/09 03:45 PM
AndyF Offline
AndyF  Offline
I bet you win a prize for being the 100th person to ask that question.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266103
03/25/09 04:24 PM
03/25/09 04:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ok , now that we have scared the guy off possibly ..
question to the thread starter ..
do you have a block or a complete UNMOLESTED shortblock ?
Or are you looking for one ? ... if you are looking for one they are easy to find , how may you ask ... check the price
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266104
03/25/09 04:35 PM
03/25/09 04:35 PM
Anonymous OP
Anonymous OP
I HAVE A 71 440 BLOCK IN THE CAR NOW I WANT A DATE CODED 440 SIX PACK BLOCK TO PUT IN TO A 70 CHALLENGER THAT IS A TRUE V CODE CAR
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266105
03/25/09 04:46 PM
03/25/09 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
All you need is an F440 HP or HP2 with the date code you think is correct. you could even goes as far as getting one with a VIN that is from the same plant that your car was built. there is absolutely no difference between a 440 non hp block , HP block or HP2 block other than the stamps ... and the PRICE ...
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: ScottSmith_Harms] #266106
03/25/09 05:37 PM
03/25/09 05:37 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Crap! I do a little bit of work and take my eyes of Moparts for just a half hour or so and I miss out!!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: DPelletier] #266107
03/26/09 12:40 AM
03/26/09 12:40 AM
Smithville .Ontario,Canada
fastback383 Offline
fastback383  Offline
Correct me if I am wrong, but I thought that the 6 pack motors had 4 "eyebrows" in the pistons ? As in valve reliefs. I realize that this involves popping a head off, but is this information correct ?? I am interested in this answer also. I have a 72 Sat (parts car) that came with a 440HP & 4 speed. The motor is supposed to be out of a 6 pack car. It has the 6 pack bottom end , it has the correct damper. The funny thing is , it is possible. This car was pieced togethor many years ago, with a ton of good parts, factory cassette deck, air grabber hood, front and rear spoilers , 2 72 RR grilles etc. Even came with a mint spare drivers door with a 71 6 pack RR vin attached to it .
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266108
03/26/09 12:46 AM
03/26/09 12:46 AM
hemisurfer Offline
hemisurfer  Offline
I am pretty sure the motor home I got my 440 block from had a six pack.
Chris
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: hemisurfer] #266109
03/26/09 01:01 AM
03/26/09 01:01 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I parted one out that had two six packs, but they were both in the 'fridge.
Lucky me.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: fastback383] #266110
03/26/09 01:37 AM
03/26/09 01:37 AM
DPelletier Offline
DPelletier  Offline
You're correct; there are a few things (like the valve reliefs) that are unique to a 440-6 but it's irrelevant unless you KNOW the engine hasn't been changed or rebuilt in the last 39 years.
OTOH there is no such thing as a "six pack bottom end": all HP motors starting in '70 used those rods and damper......and as it's already been said, there is nothing unique about the block itself.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: DPelletier] #266111
03/26/09 07:25 AM
03/26/09 07:25 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
So.. all 70+ 440HP engines have "six pack" rods and the elliptical "six pack" damper?
RS23L7 4-Speed
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: Mopar_Mike] #266112
03/26/09 09:28 AM
03/26/09 09:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Correct till about 73 or 74 ...
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266113
03/26/09 11:40 AM
03/26/09 11:40 AM
DPelletier Offline
DPelletier  Offline
Yep, what John said......which is why the term "six pack rods" is the biggest misnomer in Mopar history.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266114
03/26/09 01:23 PM
03/26/09 01:23 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
And to those enthusiasts on a Mopar learning curve, the above discussion does not apply to the '69 440-6 and 440 Six Pack.
Rods, pistons & balancer are the same used on the 440 Commando and 440 Magnum.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266115
03/26/09 02:21 PM
03/26/09 02:21 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
If I understand this bulletin correctly, in late 1971 the 440 engine got different pistons and different crank.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: mccannix] #266116
03/26/09 05:51 PM
03/26/09 05:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can you post that so it can be READ ???
