HOW TO TELL IF ITS A 440 6-PACK BLOCK
#266097
03/25/09 02:31 PM
03/25/09 02:31 PM
How can you tell if a block is from a 440 6-pack motor?
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK
#266101
03/25/09 03:43 PM
03/25/09 03:43 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Stating some obvious stuff: If its original paint is turquoise or light blue, it's not...
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
#266103
03/25/09 04:24 PM
03/25/09 04:24 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
ok , now that we have scared the guy off possibly .. question to the thread starter .. do you have a block or a complete UNMOLESTED shortblock ? Or are you looking for one ? ... if you are looking for one they are easy to find , how may you ask ... check the price
[Re: JohnRR]
#266104
03/25/09 04:35 PM
03/25/09 04:35 PM
I HAVE A 71 440 BLOCK IN THE CAR NOW I WANT A DATE CODED 440 SIX PACK BLOCK TO PUT IN TO A 70 CHALLENGER THAT IS A TRUE V CODE CAR
#266105
03/25/09 04:46 PM
03/25/09 04:46 PM
JohnRR
U.S.S.A.
All you need is an F440 HP or HP2 with the date code you think is correct. you could even goes as far as getting one with a VIN that is from the same plant that your car was built. there is absolutely no difference between a 440 non hp block , HP block or HP2 block other than the stamps ... and the PRICE ...
[Re: DPelletier]
#266107
03/26/09 12:40 AM
03/26/09 12:40 AM
Posts: 180 Smithville .Ontario,Canada
fastback383
Correct me if I am wrong, but I thought that the 6 pack motors had 4 "eyebrows" in the pistons ? As in valve reliefs. I realize that this involves popping a head off, but is this information correct ?? I am interested in this answer also. I have a 72 Sat (parts car) that came with a 440HP & 4 speed. The motor is supposed to be out of a 6 pack car. It has the 6 pack bottom end , it has the correct damper. The funny thing is , it is possible. This car was pieced togethor many years ago, with a ton of good parts, factory cassette deck, air grabber hood, front and rear spoilers , 2 72 RR grilles etc. Even came with a mint spare drivers door with a 71 6 pack RR vin attached to it .
#266108
03/26/09 12:46 AM
03/26/09 12:46 AM
Posts: 160 Florida
hemisurfer
I am pretty sure the motor home I got my 440 block from had a six pack.
Chris
[Re: hemisurfer]
#266109
03/26/09 01:01 AM
03/26/09 01:01 AM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I parted one out that had two six packs, but they were both in the 'fridge.
Lucky me.
[Re: fastback383]
#266110
03/26/09 01:37 AM
03/26/09 01:37 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
You're correct; there are a few things (like the valve reliefs) that are unique to a 440-6 but it's irrelevant unless you KNOW the engine hasn't been changed or rebuilt in the last 39 years.
OTOH there is no such thing as a "six pack bottom end": all HP motors starting in '70 used those rods and damper......and as it's already been said, there is nothing unique about the block itself.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#266111
03/26/09 07:25 AM
03/26/09 07:25 AM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
So.. all 70+ 440HP engines have "six pack" rods and the elliptical "six pack" damper?
RS23L7 4-Speed
[Re: Mopar_Mike]
#266112
03/26/09 09:28 AM
03/26/09 09:28 AM
JohnRR
U.S.S.A.
Correct till about 73 or 74 ...
[Re: JohnRR]
#266113
03/26/09 11:40 AM
03/26/09 11:40 AM
DPelletier
Yep, what John said......which is why the term "six pack rods" is the biggest misnomer in Mopar history.
1974 'Cuda
[Re: mccannix]
#266116
03/26/09 05:51 PM
03/26/09 05:51 PM
JohnRR
U.S.S.A.
If I understand this bulletin correctly, in late 1971 the 440 engine got different pistons and different crank.
Can you post that so it can be READ ???
