Product to clean aluminum intake and heads #2660862
05/31/19 09:35 AM
05/31/19 09:35 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hi Fellas,
I'm looking for a product to clean aluminum intakes manifolds and cylinders heads grease. Maybe for cleaning carbonizing in heads also. Any tips?
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Product to clean aluminum intake and heads [Re: 360tripleblack77] #2660886
05/31/19 11:02 AM
05/31/19 11:02 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Haven't used any yet, but had this recommended earlier when I asked the same question.
http://www.orisonmarketing.com/pistonkleen.html
Re: Product to clean aluminum intake and heads [Re: John Brown] #2660924
05/31/19 12:26 PM
05/31/19 12:26 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
A mild phosphoric acid solution with dawn detergent, add a little MEK if its real grimy...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Product to clean aluminum intake and heads [Re: 360tripleblack77] #2660970
05/31/19 02:30 PM
05/31/19 02:30 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Most of the really good carbon cleaners have been obsoleted due to environmental concerns. One that does come to mind is GM Top Engine Cleaner, which I think a version still exists.
I think oven cleaner does a good job on intakes. Just be careful using it. Don't let it set too long or it could etch the material. Maybe try on a couple small spots.
Bead blasting works too.
Re: Product to clean aluminum intake and heads [Re: 360tripleblack77] #2660976
05/31/19 03:08 PM
05/31/19 03:08 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
Try the dishwasher when the wife isn’t home.
Re: Product to clean aluminum intake and heads [Re: 360tripleblack77] #2660984
05/31/19 03:45 PM
05/31/19 03:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If there's a truck stop near you, they usually have aluma bright. You can get it on eBay.
Re: Product to clean aluminum intake and heads [Re: rickraw] #2661060
05/31/19 09:18 PM
05/31/19 09:18 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Oxalic acid. Gets oxidation out of the aluminum pores and is a standby wheel cleaner and its cheap.
Re: Product to clean aluminum intake and heads [Re: A/MP] #2661064
05/31/19 09:42 PM
05/31/19 09:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Raw unpolished aluminum I like Castrol Super Clean. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Product to clean aluminum intake and heads [Re: 360tripleblack77] #2661074
05/31/19 10:27 PM
05/31/19 10:27 PM
Eagle or Mequiars cast aluminum wheel cleaner works very well on cast aluminum V.C. and intakes up scope
Re: Product to clean aluminum intake and heads [Re: Cab_Burge] #2661113
06/01/19 07:42 AM
06/01/19 07:42 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Another vote here for Mag Wheel cleaner.
Re: Product to clean aluminum intake and heads [Re: dizuster] #2661136
06/01/19 09:17 AM
06/01/19 09:17 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
another vote for the ALUMINUM wheel cleaner.
Re: Product to clean aluminum intake and heads [Re: Cab_Burge] #2661204
06/01/19 12:38 PM
06/01/19 12:38 PM
Let it sit and soak for a little while, DO NOT let it start to dry before rinsing though tsk
Rinse thoroughly up
Re: Product to clean aluminum intake and heads [Re: Cab_Burge] #2661280
06/01/19 05:32 PM
06/01/19 05:32 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Find somebody that does water blasting
