60 to 70 B body Question #2660821
05/31/19 03:37 AM
05/31/19 03:37 AM
Pa.
Tek52 Offline OP
Tek52  Offline OP
Pa.
Can anyone tell me, in the trunk of a 69 to 70 B Body, can the dropoff- the trunk floor piece that goes from the trunk floor across and down inside the lower quarter panel, can it be changed with the quarter panel in place?
I'd like to find out before I start cutting-- and maybe avoid a bad surprise!
Any advice is appreciated.
Thanks, Paul
Re: 60 to 70 B body Question [Re: Tek52] #2660867
05/31/19 10:03 AM
05/31/19 10:03 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The tough part will be getting a cutter in there to remove the spot welds. The answer is "yes" it could be done but it will be one hell of a job !! If you are going to tackle it I'd suggest cutting most of it out from inside the trunk and then you can get at most of the spot welds from inside. The tough ones will be where it joins the trunk panel. Those could be tackled with a die grinder or something like that. Good luck !
Re: 60 to 70 B body Question [Re: Tek52] #2662038
06/03/19 10:11 PM
06/03/19 10:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Drill the spot welds that are easy to get to. When you get to the trunk to drop offs, cut it flush to where it meets the floor and use a grinder to remove whats left to the trunk... you can just grind where the spot welds are, just take your time so you don't grind through the trunk floor too. Even with the quarter removed, this way is easier than drilling out the spot welds.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 60 to 70 B body Question [Re: Silver70] #2662150
06/04/19 09:21 AM
06/04/19 09:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Oh yeah?!?! Which one's are "easy to get to" ???
Re: 60 to 70 B body Question [Re: Stanton] #2662439
06/04/19 11:31 PM
06/04/19 11:31 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Originally Posted by Stanton
Quote
Bottom of the quarter, up underneath the bumper, lower wheel opening.... didn't think that part was hard to figure out laugh2
Re: 60 to 70 B body Question [Re: Silver70] #2663348
06/07/19 04:39 AM
06/07/19 04:39 AM
Pa.
Tek52 Offline OP
Tek52  Offline OP
Pa.
For the hard to reach areas, I really like a Dremel tool, with the small reinforced cutting wheels.
And, patience.
Paul
