Product to clean aluminum intake and heads
#2660862
05/31/19 09:35 AM
05/31/19 09:35 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Hi Fellas,
I'm looking for a product to clean aluminum intakes manifolds and cylinders heads grease. Maybe for cleaning carbonizing in heads also. Any tips?
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Product to clean aluminum intake and heads
[Re: John Brown]
#2660924
05/31/19 12:26 PM
05/31/19 12:26 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
A mild phosphoric acid solution with dawn detergent, add a little MEK if its real grimy...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 360tripleblack77]
#2660970
05/31/19 02:30 PM
05/31/19 02:30 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Most of the really good carbon cleaners have been obsoleted due to environmental concerns. One that does come to mind is GM Top Engine Cleaner, which I think a version still exists.
I think oven cleaner does a good job on intakes. Just be careful using it. Don't let it set too long or it could etch the material. Maybe try on a couple small spots.
Bead blasting works too.
[Re: Cab_Burge]
#2661204
06/01/19 12:38 PM
06/01/19 12:38 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Eagle or Mequiars cast aluminum wheel cleaner works very well on cast aluminum V.C. and intakes Let it sit and soak for a little while, DO NOT let it start to dry before rinsing though Rinse thoroughly
