2016 5.7 core. #2659638
05/27/19 01:46 PM
05/27/19 01:46 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So i picked up a complete 5.7 out of a 2016 challenger.
Hydro locked and snapped a rod. Didn't touch the head or cylinder wall.
This thing is new inside i would guess less than 10k on engine.
Questions
I am replacing the rod with and earlier 5.7 rod. Are they the same weight?
I'm pressure testing the head and block. Don't know why it hydro locked. Possible bad gasket from factory?
What else should i look for?
Thx Matt
Re: 2016 5.7 core. [Re: MattW] #2659812
05/28/19 12:41 AM
05/28/19 12:41 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
have a machine shop weigh another rod in the block compared to the replacement--also would have them check the crank--it could have a bend that you cant see by eye...
Re: 2016 5.7 core. [Re: savoy64] #2659831
05/28/19 03:43 AM
05/28/19 03:43 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Why not just buy the correct rod and piston
Re: 2016 5.7 core. [Re: savoy64] #2659913
05/28/19 10:24 AM
05/28/19 10:24 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Did think about the crank.
Re: 2016 5.7 core. [Re: L4staero] #2659915
05/28/19 10:26 AM
05/28/19 10:26 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Have a used rod that is free and the piston wasn't damaged.
But it not to say that i may have to go that route if i find more damage.
Re: 2016 5.7 core. [Re: MattW] #2659920
05/28/19 10:32 AM
05/28/19 10:32 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
even if you buy a new rod and piston the machine shop will have to weigh them to be sure it matches....then make the replacement match the original...
Re: 2016 5.7 core. [Re: savoy64] #2660043
05/28/19 02:54 PM
05/28/19 02:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the earlier rods are lighter and flimsier
Re: 2016 5.7 core. [Re: HotRodDave] #2660262
05/29/19 10:35 AM
05/29/19 10:35 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Ah don't tell me that!!
Guest I'm getting a piston rod combo.
I will be pressure check everything before hand.
Re: 2016 5.7 core. [Re: MattW] #2660263
05/29/19 10:37 AM
05/29/19 10:37 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
1 what is this?
Re: 2016 5.7 core. [Re: MattW] #2660359
05/29/19 02:25 PM
05/29/19 02:25 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks like a stain. No telling from here though.
Might want to mag it to be sure and run a hone through it.
Rich H.
Esse Quam Videri
Re: 2016 5.7 core. [Re: ZIPPY] #2660374
05/29/19 03:35 PM
05/29/19 03:35 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I think your correct. But im going low budget on this thing. After I pressure test the block and heads.
Who has an 09 and up 5.7 rod they want to get rid of?
Re: 2016 5.7 core. [Re: MattW] #2660580
05/30/19 11:10 AM
05/30/19 11:10 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You can get rods on ebay for like 30 bucks
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 2016 5.7 core. [Re: Silver70] #2660646
05/30/19 03:20 PM
05/30/19 03:20 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thx ill look.
Definitely need the newer version
Re: 2016 5.7 core. [Re: MattW] #2661334
06/01/19 08:30 PM
06/01/19 08:30 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Have all the rods checked. I am doing a hydro locked engine right now. It had one broke rod and two that you could see were bent. When I measured the rest I found two more bent.
Re: 2016 5.7 core. [Re: crowbait] #2663826
06/08/19 06:16 PM
06/08/19 06:16 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There is no such thing as a budget build with a late model hemi, fukin core motors around here are $2500 still
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 2016 5.7 core. [Re: astjp2] #2664232
06/10/19 01:46 AM
06/10/19 01:46 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I buy them out the junkyards here for 500 or so. Bought a 6.1 with spun rod bearing on ebay for 600, set up freight which was 85 bucks... just got to shop around.
Re: 2016 5.7 core. [Re: Silver70] #2664450
06/10/19 03:29 PM
06/10/19 03:29 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Just pressure checked the head.
Good to go so far.
Re: 2016 5.7 core. [Re: MattW] #2664451
06/10/19 03:30 PM
06/10/19 03:30 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Time for a thicker piece of plexiglass.
Re: 2016 5.7 core. [Re: MattW] #2665087
06/12/19 11:22 AM
06/12/19 11:22 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why don’t you get a nice cut to size piece of thick lexan. That’s what I do when I make head adaptors for my flowbench
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
