Re: 2016 5.7 core.
[Re: savoy64]
#2659913
05/28/19 10:24 AM
05/28/19 10:24 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
have a machine shop weigh another rod in the block compared to the replacement--also would have them check the crank--it could have a bend that you cant see by eye... Did think about the crank.
Re: 2016 5.7 core.
[Re: L4staero]
#2659915
05/28/19 10:26 AM
05/28/19 10:26 AM
MattW
Ontario Canada
Why not just buy the correct rod and piston Have a used rod that is free and the piston wasn't damaged. But it not to say that i may have to go that route if i find more damage.
Re: 2016 5.7 core.
[Re: savoy64]
#2660043
05/28/19 02:54 PM
05/28/19 02:54 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
the earlier rods are lighter and flimsier
Re: 2016 5.7 core.
[Re: HotRodDave]
#2660262
05/29/19 10:35 AM
05/29/19 10:35 AM
MattW
Ontario Canada
the earlier rods are lighter and flimsier Ah don't tell me that!! Guest I'm getting a piston rod combo. I will be pressure check everything before hand.
Re: 2016 5.7 core.
[Re: MattW]
#2660359
05/29/19 02:25 PM
05/29/19 02:25 PM
Posts: 17,896 S.E. Michigan
ZIPPY
S.E. Michigan
Looks like a stain. No telling from here though. Might want to mag it to be sure and run a hone through it.
Rich H.
Esse Quam Videri
Re: 2016 5.7 core.
[Re: MattW]
#2660580
05/30/19 11:10 AM
05/30/19 11:10 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
You can get rods on ebay for like 30 bucks
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 2016 5.7 core.
[Re: crowbait]
#2663826
06/08/19 06:16 PM
06/08/19 06:16 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
There is no such thing as a budget build with a late model hemi, fukin core motors around here are $2500 still
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: 2016 5.7 core.
[Re: astjp2]
#2664232
06/10/19 01:46 AM
06/10/19 01:46 AM
Silver70
Rust Belt, SW PA
I buy them out the junkyards here for 500 or so. Bought a 6.1 with spun rod bearing on ebay for 600, set up freight which was 85 bucks... just got to shop around.
Re: 2016 5.7 core.
[Re: MattW]
#2664451
06/10/19 03:30 PM
06/10/19 03:30 PM
MattW
Ontario Canada
Time for a thicker piece of plexiglass.
Re: 2016 5.7 core.
[Re: MattW]
#2665087
06/12/19 11:22 AM
06/12/19 11:22 AM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why don’t you get a nice cut to size piece of thick lexan. That’s what I do when I make head adaptors for my flowbench
