swing gate milodon oil pan #265745
03/25/09 01:14 AM
03/25/09 01:14 AM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
i have a milodon swing gate oil pan with dual lines and the steering link running thru it...9 qt...it has teflone washers and nuts on each side[in and outside] which has been leaking since day one when i installed the motor....what do you guys think on the fix.....rtv silicone...o rings??
Post deleted by Defbob [Re: GEORGE68HEMIRR] #265746
03/25/09 01:21 AM
03/25/09 01:21 AM
Re: swing gate milodon oil pan #265747
03/25/09 01:27 AM
03/25/09 01:27 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
thanks fred...you think milodon wouldve done that to the pan in the first place
Re: swing gate milodon oil pan [Re: GEORGE68HEMIRR] #265748
03/25/09 01:34 AM
03/25/09 01:34 AM
AndyF Offline
AndyF  Offline
I use #12 AN bulkhead fittings with special washers and a little RTV. Never had a leak.
Re: swing gate milodon oil pan [Re: AndyF] #265749
03/25/09 01:44 AM
03/25/09 01:44 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
those special washers are teflon?
Re: swing gate milodon oil pan [Re: GEORGE68HEMIRR] #265750
03/25/09 06:32 AM
03/25/09 06:32 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Doty Engineering makes some washers that seal pretty good.
I want my fair share
Re: swing gate milodon oil pan [Re: GEORGE68HEMIRR] #265751
03/25/09 09:22 AM
03/25/09 09:22 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
One of the external fittings are leaking on my 572 as well I am planning on replacing the o ring and using some sealer this time around. Maybe I should find some nylon washers as well?
Re: swing gate milodon oil pan [Re: GEORGE68HEMIRR] #265752
03/25/09 09:50 AM
03/25/09 09:50 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Re: swing gate milodon oil pan [Re: 540dust] #265753
03/25/09 10:41 AM
03/25/09 10:41 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Dowty washers
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: swing gate milodon oil pan [Re: 540dust] #265754
03/25/09 10:42 AM
03/25/09 10:42 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
http://www.magnumhp.com/catalog/product_info.php?products_id=305
guys thanks for your help...have to try o-rings and silicon
