/6 To 360 Magnum Parts and Labor Checklist #265506
03/24/09 09:06 PM
03/24/09 09:06 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
I'm swapping in a stock 96 360 Magnum into my 68 Valiant and want to make sure I have everything before I start, so can you all please double check my list?
-Schumacher /6-V8 mounts
-LA-style timing cover and water pump
-LA-style distributor w/MP ignition
-LA-style pulleys, brackets and fan
-V8 carb linkage
And a couple of questions:
-can I use the Magnum exhaust manifolds from a truck?
-when I go to the car oil pan, do I need to use a center sump pickup?
-since Im changing the timing cover, Im assuming I need to change the cam to an earlier LA-style (with fuel pump drive)
-I have a new M1 intake-is that too much with a 340-ish cam even if I use a small 650 carb? If so, what other intakes are out there for the Magnum heads?
-the /6 has a 904 trans and Im just going to use a V8 A904-Im assuming that other than the bellhousing, theyre the same?
-the Magnum engines are externally balanced(?); do I need a counterbalanced flywheel?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265507
03/24/09 10:28 PM
03/24/09 10:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
-V8 carb linkage
Are the /6 and V-8 wiring harnesses the same for your Valiant? I ran into that issue during my Aspen /6--> 360 swap.
Air cleaner assembly?
Radiator?
Raditaor hoses, especially the upper hose?
Fan spacer of the correct length?
Fan shroud?
Yes
--the /6 has a 904 trans and Im just going to use a V8 A904-Im assuming that other than the bellhousing, theyre the same?
You use a flexplate with an automatic, as flywheels are for manual transmissions. No clue as to which one you'll need, sorry.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: In_The_Pink] #265508
03/24/09 10:47 PM
03/24/09 10:47 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Dan, I am at the end of my swap with mine. The Demon gets it's heart in about a month. I need to know what you're planning on reusing first, then I can give you a full list. I'm actually also in the middle of writing an article about the entire swap (tips, tricks, part numbers, etc) because there's such fragmented documentation online.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265509
03/24/09 10:54 PM
03/24/09 10:54 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
As for your questions:
1. The magnum exhaust manifolds only fit in an early A.
2. Just buy the 360 center-sump pan/pickup combo from MP
3. The cam needs to be a Magnum roller cam with a long snout ordered on a core. I got a Hughes HER1804ALN As an alternative, you can use a stock cam, and get Hughes' bolt kit and a MP fuel pump eccentric to attach to the end of it.
4. If it's the M1 single-plane, then it might be too much for a stockish cam. Edelbrock and Performance Products make a dual-plane, as does MP, but the problem with the PP one is bad runner alignment. The cheapest Edelbrock is at Hughes, $245.95
5. The transmissions are the same from trucks to A-bodies, but I don't know about vans. You'll have the balancer from a Magnum which is offset, so the easiest way to do it is to get a 5.9 Magnum flexplate and a neutrally-balanced torque converter (318 torque converters are neutral)
Hope this helps.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265510
03/24/09 11:49 PM
03/24/09 11:49 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I also went with the cam snout adaptor route.
Learned the hard way that the stock cam sucks.
It's barely tips the valves off their seat. The stock Magnum camshaft is 0.39/0.40" lift.
Decent torque. It's make more torque at idle than some engines do at 2000rpm. Here is my truck in 1st gear.
http://www.youtube.com/watch?v=nCmRdB1isoY&feature=player_embedded
Problem is there is nobody home after 4000rpm.
I recommend a cam swap.
The B&M flex plate is the easiest solution to the balance issue.
http://www.bmracing.com/PRODUCTS/Chrysler-SFI-29-1-approved/SFI-Flexplate-Chrysler_7
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265511
03/25/09 08:23 AM
03/25/09 08:23 AM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
I am using the pro products intake on the 96 magnum that I have and I was lucky enough to have a buddy here on moparts find me a create motor cam from a member here and its perfect for my application.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Magnum] #265512
03/25/09 08:37 AM
03/25/09 08:37 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd use the hughes adapter for the cam, and get yours reground at http://www.deltacam.com/ or http://www.bulletcams.com/
I'd swap to GM3100 valve springs & retainers, and for lobes, I'd go with something like the HR262/300 lobe
on bullets master lobe list (http://www.bulletcams.com/Masters/HRlobes.htm) I'd probably do it as a single pattern cam.
2017 Grand Cherokee Overland
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: patrick] #265513
03/25/09 09:19 AM
03/25/09 09:19 AM
Southern Wisconsin
hillsidehemi Offline
Southern Wisconsin
So the way I understand it is if you use the B&M flexplate mentioned you can use a converter from a transmission that was previously on a LA 360?
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: hillsidehemi] #265514
03/25/09 09:37 AM
03/25/09 09:37 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
HI, there is a tread that covers these swap right now, from IMGTX....
You will need an extension for the fuel pump arm,. I think Mancini sells those...
Stock manifold won't fit, It will hit the steering column, you need to get LA style A-body headers to clear every thing. Yes the 904 bolts right on, keep the magnum flexplate and use the 904 torque, but make sure to upgrade your tranny and put a deep oilpan, otherwise it will not hold..
Use the oil pan fron a pass car V8 for the engine..
I'm doing this swp right now in my 67 Battacuda
Daniel
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Wedgeman] #265515
03/25/09 03:02 PM
03/25/09 03:02 PM
thanks guys, I scrolled through the Q&A and best of for awhile looking for Magnum installs and couldnt find anything so I may archive this. Sharpie, please pass along as much as possible and we'll archive it as well.
Anyway, Im doing this with as much leftover parts as possible from the 408 build I did for my truck, I dont want to buy any major parts and I have a complete 360 Magnum leftover. I already have a car oil pan (no pickup though, but easy enough to get)
Id like to try and make the exhaust manifolds work without having to buy headers-can they be notched or something? Do they hit the steering box or m/c? (its a manual brake/manual steering car)
I already have the M1 intake; not my first choice but I'll give it a try. I also forgot that I had a brand new, in the box Magnum roller cam for a 360/390 crate motor (isnt that a .509 or similar?) so maybe that will work OK with the intake.
Im also going to try and use the radiator in the car-its an A/C car so I'll give it a shot with universal fitting hoses.
So no flexplate issues with the 904?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265516
03/25/09 03:46 PM
03/25/09 03:46 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Dan...
I did a trial fit last week-end with the truck mainfold and they were hitting the steering box and colum.....depending on the engine mounts you have, you may try to shimm with 1/4 steel plates..but one can not go too high because you won't be able to close the hood, so the last option we have is to get those headers....
Also,on an another tread from IMGTX, it has been discussed that the Durango offset bracket would do in our cars.....anyway, try it on , you'll see
So far, I have no promblems with the 904...
Daniel
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265517
03/25/09 03:47 PM
03/25/09 03:47 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IMGTX's problem with the mag manifolds was it was hitting the PS box. a manual steer car it might fit...you'll have to try.
the 380/390 crate motor cam is ~ .512" lift, 288/294 adv and IIRC ~230/236@.050 on a 108 LSA.
that cam, LA timing cover, the MP .525" lift valve springs, and an M1 single plane are really the only functional differences between an OEM truck motor and a 380 horse crate.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: patrick] #265518
03/25/09 04:33 PM
03/25/09 04:33 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Dan, basically the issue with the flexplate or torque converter is that one should be neutrally balanced and one should be balanced to counter-act the dampner.
The B&M flexplate is said to be for a 727. Should work on a 904 as well, but I haven't seen it even attempted. The easiest way to take care of the balancing problem is to balance the balancer to the flexplate and then get a neutrally-balanced converter, since they are more plentiful. You COULD get a torque converter balanced to the dampner and use a 360 LA flexplate, but that's usually more time and money spent.
Let me know if you need anymore specific information. I am almost through my research for the article (serious research going into all of the options) and would like to have it done by June. I will let you know so you can archive it.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265519
03/25/09 05:08 PM
03/25/09 05:08 PM
W
Wedgeman Offline
Wedgeman  Offline
W
I'll be using the flexplate from the Magnum with the neutrally balanced torque from my 904.....
Daniel
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265520
03/25/09 05:49 PM
03/25/09 05:49 PM
Andrewh Online content
Andrewh  Online Content
There is a GMC hose for one of the trucks that seems to work very well.
At least for me for the upper rad. I tried a lot of different ones so I could clear the a/c and what not. If you look at the other magnum thread I have a few pics up. Depends on where your rad opening is though.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265521
03/26/09 06:00 AM
03/26/09 06:00 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'll be doing this swap on my Duster soon Dan, I have three sets of manifolds to try (van, 92 Ram and 96 Jeep)
The Jeep manifolds are very different than the truck or van units.
Gary
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: gdonovan] #265522
03/26/09 08:54 AM
03/26/09 08:54 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Gary,
Don't know about the Jeep ones....what would fit is a 68-70 340 style driver's side manifold, the one going upward.....you know ?
Daniel
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Wedgeman] #265523
03/26/09 10:28 AM
03/26/09 10:28 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I will be testing Dakota shortie headers soon. The measurements look close but look like they'll fit. We'll see though.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265524
03/26/09 11:18 AM
03/26/09 11:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
which shorties? do you have power steering and brakes?
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: patrick] #265525
03/26/09 11:44 AM
03/26/09 11:44 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
They're in the style of these:
I don't think they're that exact brand, but they look similar, especially the driver's side.
I have power steering but manual brakes (Wilwood plastic-resevoir master cylinder), so we'll see. I don't mind having to dent a tube or two to get it around the PS box, but we'll see what all is involved.
