The Big " IF" #2654570
05/12/19 12:08 PM
05/12/19 12:08 PM
USA
hudsonhornet7x Offline OP
USA
IF a guy was able to purchase a hemi block what are some good running combinations out there? If you were to propel a 68 B body to the very low 10's or possibly high 9's in the right conditions what would it take? The car would have to remain somewhat streetable. In other words I can live with ( and honestly would want) a rough idle and don't need to worry about vacuum, etc.
Re: The Big " IF" [Re: hudsonhornet7x] #2654603
05/12/19 01:02 PM
05/12/19 01:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Arlen Vanke once told me "boy if you can't go low 10's with a production 426 by adding a roller cam, cross ram and headers you'r doing something wrong". That being said a stroker crank, lighter pistons and modern rods would be a plus.
Doug
Re: The Big " IF" [Re: hudsonhornet7x] #2654608
05/12/19 01:09 PM
05/12/19 01:09 PM
AndyF Offline
AndyF  Offline
Shoot for a weight to power ratio of 5:1 and you'll have enough on tap to run the number if you can hook it up. So 700 hp in a 3500 lb car will do the trick if you can get the power to the ground. It should not be hard to make 700 streetable HP with a stroked Hemi. A 528 with an Edelbrock top end and a modest street roller should easily top 700 hp. If I was building the car I'd use dual Holley Sniper throttle bodies on there just to make it easier to tune. Plus the internal data logging is always a plus when you're trying to sort out a combo with a lot of power. The Sniper also has built in launch control (timing retard) which might come in handy when you try to put the power down.
Re: The Big " IF" [Re: hudsonhornet7x] #2654610
05/12/19 01:11 PM
05/12/19 01:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The more streetable/low maintenance you want it....... the bigger you should make it.
Re: The Big " IF" [Re: fast68plymouth] #2654631
05/12/19 01:49 PM
05/12/19 01:49 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
As stated above, cubic inches are good friends for this accomplishment. There are guys running as quick as 9.40's in a street car with only 528 cubes. I have not gone that fast with my 605........And for arguments sake, which block are we talking about?
The standard is 572 these days. There are a lot of nice rotating assemblies for this size engine. I have a 605 and it pushes the rod pin up further into the piston, probably as far as you can go. This makes the skirt pretty short and will give you some scuffing of the walls over time. So I would recommend the 572 square 4.5 x 4.5 engine as the best all around size.
Me personally, would love to see someone come up with a hemi and wedge option in the future that would allow us to go well beyond some day.
https://www.youtube.com/watch?v=8LMsBR1dsAs
Re: The Big " IF" [Re: Dragula] #2654636
05/12/19 02:07 PM
05/12/19 02:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
I agree with the 572” plan........ as long as the block being used is suitable for it.
If you didn’t want to max out the bores at 4.500” the first go around, then I’d do a 4.440 bore x 4.50 stroke and build a 557”.
If you’re going to use a small bore block, I’d probably go with the 4.25 stroke(489/496).
Re: The Big " IF" [Re: hudsonhornet7x] #2654646
05/12/19 03:19 PM
05/12/19 03:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Originally Posted by hudsonhornet7x
what would it take?
A box the dimensions of the hemi block filled with twenty dollar bills.
Re: The Big " IF" [Re: fast68plymouth] #2654648
05/12/19 03:20 PM
05/12/19 03:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Boost is great!! Very streetable as well up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: The Big " IF" [Re: Dragula] #2654649
05/12/19 03:23 PM
05/12/19 03:23 PM
USA
USA
[quote=Dragula]As stated above, cubic inches are good friends for this accomplishment. There are guys running as quick as 9.40's in a street car with only 528 cubes. I have not gone that fast with my 605........And for arguments sake, which block are we talking about?
I figure there are two choices for the block. 1st " THE BLOCK" that has been discussed here lately from Bulldog Performance, and 2nd a Keith Black block. Those seem like the only two available at the moment.
If going with the iron block, I would like to keep the bore as small as possible for future rebuilds.
Re: The Big " IF" [Re: hudsonhornet7x] #2654655
05/12/19 03:46 PM
05/12/19 03:46 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
There are a few good pump gas 572 combinations floating around here, but I had to do a few searches
To find them and add to the research pile.
If the block you end up with is already at 4.500 as mine was, it seems the path of least resistance.
A mildly cleaned up/blended set of Victor heads and middle of the road roller seems to support
Upward of 800hp in that environment, even with relatively short duration cams.
Rich H.
Esse Quam Videri
Re: The Big " IF" [Re: ZIPPY] #2654661
05/12/19 04:09 PM
05/12/19 04:09 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Key word being B body. Build backwards to the headers, exhaust and suspension constraints. Make sure it is maintainable and uses readily available gas. Plus the tires and brakes, driveshaft, safety stuff, tranny/converter. Slippery slope there. IMO with a stock hemi in a B body, build for torque and make a buddy at the tire store cause you'll go through rear tires.
Re: The Big " IF" [Re: Airwoofer] #2654667
05/12/19 04:27 PM
05/12/19 04:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My buddy has a beautiful Duster factory block big block Mopar that has dipped into the 9.70’s and street driven often. Nothing unusual for the Pittsburgh area but this one has Mopar stage 5 or 6 heads on it. It’s not a gutting down piece and although it’s not a B body some guys make this harder than it is. Lots of good Mopar parts out there now
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The Big " IF" [Re: hudsonhornet7x] #2654717
05/12/19 07:01 PM
05/12/19 07:01 PM
Dragula Offline
Dragula  Offline
Well a friend of mine has a all aluminum 572 in a GTX street/show car. He occasionally makes a pass with it. I helped him dyno it at Jan-Cen a while back. All good parts in it. This is a full weight car right around 3800lbs.....It has run as quick as 9.87 with that engine. You want to run that fast in a heavy car, plan on lots of good parts from the suspension to the trans, to the engine.
https://www.youtube.com/watch?v=ueC_4nAdSZ4
https://www.youtube.com/watch?v=5QjkTW-o1QY
https://www.youtube.com/watch?v=M5l_w8n8gbE
Re: The Big " IF" [Re: Dragula] #2654820
05/12/19 11:26 PM
05/12/19 11:26 PM
USA
USA
Well on another site I was just offered a new in crate mopar performance hemi block for $9,500!!! That was not a typo!
Re: The Big " IF" [Re: hudsonhornet7x] #2654829
05/13/19 01:29 AM
05/13/19 01:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
Is this a crate Hemi block or complete Hemi crate engine?
Re: The Big " IF" [Re: Cab_Burge] #2654847
05/13/19 07:04 AM
05/13/19 07:04 AM
USA
USA
Crate Hemi Block!
Re: The Big " IF" [Re: hudsonhornet7x] #2654865
05/13/19 08:25 AM
05/13/19 08:25 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You can get aluminum for under 6 grand. That is nuts!
Re: The Big " IF" [Re: hudsonhornet7x] #2654890
05/13/19 09:18 AM
05/13/19 09:18 AM
an8sec70cuda Offline
I think my combo is pretty mild and simple yet runs good for a heavy car.
11:1 pump gas 572" hemi w/ cnc ported MP heads, Dwayne Porter spec'd solid roller that's very mild and easy on parts, single 4500 manifold, 727 and a 4.10 Dana on leaf springs = 9.50s at 140 mph at 3800 lbs.
Ran it NA for about 8 years or so before getting bored and decided to spray it. Now well into the 8s w/ a plate kit.
Ran it 1/8 mile this past weekend and went a new best...doing the math it would have easily been an 8.8x pass.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: The Big " IF" [Re: an8sec70cuda] #2654901
05/13/19 09:58 AM
05/13/19 09:58 AM
Dragula Offline
Dragula  Offline
Chip,
Your car always runs strong. I am hoping mine will run that hard this year. I guess we will see. I did not have mine at the drags at all last year. It was running good and wanted one year without it blowing up and to sort the big carb out. Its been rain here every day and still haven't even had it out for a cruise this year.
Here is a pic of my buddy's 572...
Re: The Big " IF" [Re: hudsonhornet7x] #2654985
05/13/19 02:11 PM
05/13/19 02:11 PM
It may be one of the older pre World cast iron blocks, no way would I pay that much for one of those blocks tsk\
Does he state the bore size or part number of the block?
