Which urethane method has least isocyanates? #2652362
05/05/19 06:52 PM
05/05/19 06:52 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
Curious to know which would contain the least isocyanates... single stage or base/clear?
Re: Which urethane method has least isocyanates? [Re: ksat] #2654123
05/10/19 07:05 PM
05/10/19 07:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Depends on the brand and product. Read the sheet on it.
Re: Which urethane method has least isocyanates? [Re: NANKET] #2654171
05/10/19 09:20 PM
05/10/19 09:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's like saying which bullet will kill me the least !! If you're gonna shoot that stuff just get a good respirator and have at it. How much isocyanates is in the product isn't the issue, its how much gets into your lungs !!
Re: Which urethane method has least isocyanates? [Re: ksat] #2654185
05/10/19 10:15 PM
05/10/19 10:15 PM
Kirkland, Washington
Pacnorthcuda Offline
Exactly, the question is what respirator is best at removing isocyanates from the air that you breathe.
Re: Which urethane method has least isocyanates? [Re: ksat] #2654242
05/11/19 07:49 AM
05/11/19 07:49 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
i am a PPG certified painter since PPG had a certification program, early 90's.
in MOST circumstances base coat does NOT have isocyanates in it. usually only the clear coat and single stage paint does. 2K sealers have it also. as posted before get a tech sheet, usually available online, and know what you are using before using it.
even without isocyanates base coat does have some harmful chemicals in it, even water base coat does, so you should ALWAYS wear a respirator when spraying it.
buy yourself a approved, i don't know the proper certification safety #'s, respirator and start spraying. a quality disposable 3M respirator from the paint store is just fine.
also i would recommend painting with safety glasses and gloves because isocyanates are absorbed thru the eyes and skin. if you want to go overboard use a paint suit also. i wear one not for exposure but for less dirt in the paint.
some people will disagree with me but approved respirators are actually only good for 24 hours of exposed air time. avoid exposing to open air as much as possible. also keep the respirator in a sealed Ziploc bag and them place it in a sealed container with a lid like a large old coffee can. remove any facial hair to make sure it seals properly and do a fit test, hold the exhaust closed with your hand and lightly exhale, after putting it on.
being a pro and spray paint almost daily, i myself paint base coat with a 3M respirator for better vision and spray clear with this, https://www.autobodytoolmart.com/sas-pure-air-2000-opti-fit-respirators-p-12219.aspx
perception is 90% of reality
Re: Which urethane method has least isocyanates? [Re: Mr T2U] #2655013
05/13/19 03:04 PM
05/13/19 03:04 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Been using a Hobbyair full face respirator for years. I use it even when isocyanates are not involved. Can't be too careful with those 2 organs that enable breathing.
