508 with Sniper makes 710 hp #2654107
05/10/19 06:21 PM
05/10/19 06:21 PM
AndyF Offline OP
AndyF  Offline OP
I helped tune a 508 inch big block today that had a Sniper with Hyperspark ignition. This is a street/strip type of engine with 10:1 compression, big Comp street roller cam, ported Indy intake, Trick Flow 270 heads and a good valvetrain. (T&D rocker arms, dual conical valve springs, etc.) So not a race engine but a street engine with really good parts in it. I think it is a Molnar 4.250 crank with 7.100 long rods and Diamond dish pistons. So better quality parts than a lot of street engines. It ended up making 710 hp at 6300 rpm and 640 torque somewhere in the low 5000 range. I didn't keep a copy of the dyno sheets since it isn't my engine. This engine really taxed the Sniper throttle body, we could tell it was choked off by 6500 rpm. So a big carb, or a bigger throttle body would've added more power up top. However, the guy wants to run the Sniper since he mostly drives it on the street. He only takes it to the track once or twice a year. It is going in a RoadRunner with a Dana 60 and four speed so he is going to have trouble getting the car to go straight!
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654130
05/10/19 07:26 PM
05/10/19 07:26 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice numbers, Andy. Can you share the cam specs?
2 kids and a dog
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654139
05/10/19 07:49 PM
05/10/19 07:49 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Nice project 👍
Rich H.
Esse Quam Videri
Re: 508 with Sniper makes 710 hp [Re: TonyS451] #2654147
05/10/19 08:26 PM
05/10/19 08:26 PM
AndyF Offline OP
AndyF  Offline OP
Nothing special on the cam, it is just a 260/266 street roller with 1.65 rocker arms. Might be a little on the big side for a street car but the guy has a four speed and deep gears out back and he just drives it for fun. He wanted 700 hp and we figured that cam would hit the number. Just barely made it with the Sniper. With a big 4150 carb it would make more power but then the guy would give up the digital jetting and timing.
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654152
05/10/19 08:35 PM
05/10/19 08:35 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Nice build. Wish Holley offered the HyperSpark in a stand alone version for carb guys.
Re: 508 with Sniper makes 710 hp [Re: HDNMOPERS] #2654196
05/10/19 10:41 PM
05/10/19 10:41 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Right on you're becoming Mr. EFI up
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654311
05/11/19 12:28 PM
05/11/19 12:28 PM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
Andy, this sounds very similar to my build. Was there any additional porting or cleanup done? What about any port matching for the intake? Just trying to get a feel for what to expect for final numbers.
Re: 508 with Sniper makes 710 hp [Re: Brewzer67] #2654337
05/11/19 01:44 PM
05/11/19 01:44 PM
AndyF Offline OP
AndyF  Offline OP
The heads are out of the box except for the valve spring change. The intake was ported since it had the typical Indy port mismatch issues.
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654480
05/12/19 01:09 AM
05/12/19 01:09 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Any worries about exceeding the stock block's limits at this level?
'63 Dodge 330
11.19 @ 121 mph
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654486
05/12/19 01:23 AM
05/12/19 01:23 AM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
Thanks Andy. I was shooting for 750-775 and think I'll be close. I've got 526" with a smidge more stroke, a tiny bit more cam, and the extra porting work brought up the mid and top range numbers(378cfm@.700) so I will hopefully be right there.
Re: 508 with Sniper makes 710 hp [Re: GY3] #2654487
05/12/19 01:28 AM
05/12/19 01:28 AM
AndyF Offline OP
AndyF  Offline OP
I don't think the block should be a problem with 10:1 compression and 6500 rpm redline but you never know. We told the owner to shift it at 6200 rpm and just let the torque move the car. No reason to beat the thing to death.
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654519
05/12/19 09:22 AM
05/12/19 09:22 AM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Andy, do you know what lobe family on that Comp cam?
and and what spring pressure it would require?
Thanks, Mike
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654536
05/12/19 10:48 AM
05/12/19 10:48 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have much the same. With lower rpm use, pump gas, etc. hoping that combined with a relatively light rotating assembly keeps my block together. I am at a little more with the 200 shot of nitrous we are trying now. runaway
Mild 600hp driver with 200hp on demand. LOL.
Re: 508 with Sniper makes 710 hp [Re: mkdart] #2654565
05/12/19 12:02 PM
05/12/19 12:02 PM
AndyF Offline OP
AndyF  Offline OP
Thanks, Mike
The cam is just a Comp street roller, same basic thing you can buy from Summit. Should work fine with the roller cam springs that come with the Trick Flow heads. The biggest street roller Comp shows in their catalog is the XR292 but this was one size larger which would be the XR298.
Re: 508 with Sniper makes 710 hp [Re: AndyF] #2654951
05/13/19 12:21 PM
05/13/19 12:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That will be a fun street motor.
Re: 508 with Sniper makes 710 hp [Re: ProSport] #2654957
05/13/19 12:31 PM
05/13/19 12:31 PM
an8sec70cuda Offline
iagree up
CHIP
'06 GMC 2500HD LBZ Duramax
