Aluminum water pump housing for BB #2653263
05/08/19 06:31 AM
05/08/19 06:31 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
It’s been awhile since I bought one of these and noticed they have gone up. The 440 source is much cheaper than Mancini or summit. Is there’s ok? I heard the pumps may not be that great.
Re: Aluminum water pump housing for BB [Re: fastmark] #2653265
05/08/19 07:06 AM
05/08/19 07:06 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've had a 440 source pump and housing on my one car since 2008 and haven't had an issue. I bought the passenger side outlet for my other car about 3 years ago and no issues with it. I'd buy another one.
Re: Aluminum water pump housing for BB [Re: DusterKid] #2653267
05/08/19 07:09 AM
05/08/19 07:09 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've run the Source pump and housing for 5700 miles and hundreds of dragstrip passes. No issues at all.
'63 Dodge 330
11.19 @ 121 mph
Re: Aluminum water pump housing for BB [Re: GY3] #2653268
05/08/19 07:12 AM
05/08/19 07:12 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
On eBay for $53 shipped to your door.
https://www.ebay.com/itm/fits-Chrysler-Mopar-BB-360-383-440-High-Volume-Aluminum-Water-Pump-Housing-Ony/291748195503?epid=14004118719&hash=item43ed8c2caf:g:wysAAOSwK~RaAk8L
69 GTX 68 Road Runner
Re: Aluminum water pump housing for BB [Re: JERICOGTX] #2653269
05/08/19 07:15 AM
05/08/19 07:15 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I first bought the source housing with the passenger side inlet, made finding a radiator harder. Then bought their standard configure housing. Works fine and would buy again.
Re: Aluminum water pump housing for BB [Re: varunner] #2653288
05/08/19 08:35 AM
05/08/19 08:35 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks guys.
Re: Aluminum water pump housing for BB [Re: fastmark] #2653426
05/08/19 03:42 PM
05/08/19 03:42 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I have had some friends that were unlucky with the 440 Source pump that started to leak after a year or 2 ! I prefer the mp or milodon hv pump and you should look at the clearance so the inpeller dont hit the housing before install but 440 source housings should be fine to use wave
