Which air filter to use? #265299
03/24/09 07:51 PM
03/24/09 07:51 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
I bought this air cleaner a while back for my 360 from eBay. It had the "440" decal on it before I sanded it down, repainted it and put the 360 decal on it. While I was at the auto parts store the other day, I figured I'd pick up an air filter for it, before I realized that I had no idea what it came from, so I couldn't look it up in the 'book' by the air filters..
Also, not quite sure where to hook up the vacuum fitting to that's on the 'snout', and there are a couple underneath too.. any thoughts on those?
anyone have an idea?
Re: Which air filter to use? [Re: cal_gecko] #265300
03/24/09 07:52 PM
03/24/09 07:52 PM
Sacramento, CA
Sacramento, CA
2
Re: Which air filter to use? [Re: cal_gecko] #265301
03/24/09 08:12 PM
03/24/09 08:12 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Looks like a normal 2"x14" air filter to me. I'd just take the entire air cleaner to Vatozone and have them match one.
Re: Which air filter to use? [Re: cal_gecko] #265302
03/24/09 08:14 PM
03/24/09 08:14 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i could be wrong, but it looks 180 degrees off...should the snorkel be on the other side?...the cut out for the thermostat is shown in the back...should be up front....but then again...u said it was from a big block....could be different
Re: Which air filter to use? [Re: AARCONV] #265303
03/24/09 08:17 PM
03/24/09 08:17 PM
Sacramento, CA
Sacramento, CA
You may be right... I didn't realize that cutout was for the thermostat .. I thought it was for the distributor wires, LOL.
Thanks Sharpie, that was my next step.
LOL at "Vatozone"
Re: Which air filter to use? [Re: cal_gecko] #265304
03/24/09 08:25 PM
03/24/09 08:25 PM
Also, not quite sure where to hook up the vacuum fitting to that's on the 'snout', and there are a couple underneath too.. any thoughts on those? anyone have an idea?
underneath the "air temperature thermostat" has 2 nipples, run one to a manifold vacuum source on carb baseplate, the other goes to the "hot air vacuum servo" on top. only caveat is IF the 2 nipples underneath on the stat have an "in and an "out". If so they may be marked or someone else will chime in on this
Re: Which air filter to use? [Re: cal_gecko] #265305
03/24/09 08:51 PM
03/24/09 08:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Which air filter to use? [Re: cal_gecko] #265306
03/24/09 08:58 PM
03/24/09 08:58 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
RR covered it above, but if you don't have a warm air tube connecting the snorkel and exhaust manifold, you may as well leave the vac lines off the air cleaner assembly, as the flapper door should remain down and leave the snorkel in the 'open' postiion.
