Loud poping noise, shutting trunk #265295
03/24/09 07:28 PM
03/24/09 07:28 PM
car48nut Offline OP
car48nut  Offline OP
When ever I open or shut my trunk(68 roadrunner)I have a loudpoping or binding noise, It happens when the trunk is about all the way open and when it closes, it is at the start off closing it. I had my son get in the trunk and look when I clos ed it. He said that the one torsion bar end acted like it had a bind to it. The noise came when it moved in the bracket. on the right side. Any sugestions on the cause?
Re: Loud poping noise, shutting trunk [Re: car48nut] #265296
03/24/09 08:50 PM
03/24/09 08:50 PM
O
otter440 Offline
otter440  Offline
O
try a set of new blocks on the ends of the torsion bars. Take some vaseline and wip it on where the slids move. Hope this helps
Re: Loud poping noise, shutting trunk [Re: otter440] #265297
03/24/09 11:50 PM
03/24/09 11:50 PM
car48nut Offline OP
car48nut  Offline OP
I will try that . I have never had anything like that happen before.
Re: Loud poping noise, shutting trunk [Re: car48nut] #265298
03/26/09 08:03 PM
03/26/09 08:03 PM
car48nut Offline OP
car48nut  Offline OP
I tried the blocks, a used set, all that I had, that did not work. anybody else have an idea? Thanks
