440 sixpack mechanical linkage #2648853
04/25/19 01:03 PM
04/25/19 01:03 PM
Ia, US
P
PTHemi Offline OP
PTHemi  Offline OP
P
Ia, US
looking to put mechanical linkage back on my A 12 roadrunner. It originally had mechanical linkage and at this time I've missed placed it. I don't like the way the vacuum set up is running and would like to go back to mechanical. If anybody knows a vendor that carries this I would much appreciate it. thanks..... Ray
Re: 440 sixpack mechanical linkage [Re: PTHemi] #2649085
04/25/19 11:35 PM
04/25/19 11:35 PM
Are you saying you have original mechanical carbs. converter to vacuum now or are yours vacuum converter to mechanical linkage?
I've had both, none converter from mechanical to vacuum confused
Re: 440 sixpack mechanical linkage [Re: PTHemi] #2649263
04/26/19 12:23 PM
04/26/19 12:23 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Ray- I found this old thread from 2008 that talks about the vacuum and mechanical outboard carbs. Give it a read. Do you or did you at some point have the outer mechanical carbs with accelerator pumps? Or did you have the "Six Packs To Go" setup? It don't look like any of that stuff is available anymore that I can find. I guess what I'm trying to say is if your carbs had the "Six Packs To Go" mods and then were converted back to vacuum at some point, that may be why they are not working properly.
Mechanical vs Vacuum 6 pack setup
Re: 440 sixpack mechanical linkage [Re: PTHemi] #2649303
04/26/19 02:02 PM
04/26/19 02:02 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are a lot mechanical set ups available,you can make anything work. twocents
Re: 440 sixpack mechanical linkage [Re: 62maxwgn] #2649325
04/26/19 03:04 PM
04/26/19 03:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
popcorn
Re: 440 sixpack mechanical linkage [Re: BradH] #2649331
04/26/19 03:25 PM
04/26/19 03:25 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Ray do you remember what the linkage looked like? Something like this?
Re: 440 sixpack mechanical linkage [Re: ratroaster] #2649360
04/26/19 05:11 PM
04/26/19 05:11 PM
MD
floyd Online content
floyd  Online Content
MD
Yours if you want any of this.
Re: 440 sixpack mechanical linkage [Re: 62maxwgn] #2649381
04/26/19 05:48 PM
04/26/19 05:48 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Thanks for the input.
Re: 440 sixpack mechanical linkage [Re: floyd] #2649468
04/27/19 03:49 AM
04/27/19 03:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yeah I think I have a couple of those set-ups too
Re: 440 sixpack mechanical linkage [Re: Morty426] #2649528
04/27/19 11:33 AM
04/27/19 11:33 AM
Ia, US
P
PTHemi Offline OP
PTHemi  Offline OP
P
Ia, US
Floyd, that's the one ....msg.sent. thanks Mark for pic....Morty keep a set aside I might need a set for a 70 Bee ... Ray
Re: 440 sixpack mechanical linkage [Re: ratroaster] #2651159
05/02/19 10:20 AM
05/02/19 10:20 AM
uk
TiMopar Offline
TiMopar  Offline
uk
That linkage was made by 'Ansen', I used one on my A12 Bee in the olden days... worked well!
