Re: 440 sixpack mechanical linkage
[Re: PTHemi]
#2649085
04/25/19 11:35 PM
04/25/19 11:35 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
Are you saying you have original mechanical carbs. converter to vacuum now or are yours vacuum converter to mechanical linkage? I've had both, none converter from mechanical to vacuum
[Re: PTHemi]
#2649263
04/26/19 12:23 PM
04/26/19 12:23 PM
Posts: 318 Iowa
ratroaster
Iowa
Ray- I found this old thread from 2008 that talks about the vacuum and mechanical outboard carbs. Give it a read. Do you or did you at some point have the outer mechanical carbs with accelerator pumps? Or did you have the "Six Packs To Go" setup? It don't look like any of that stuff is available anymore that I can find. I guess what I'm trying to say is if your carbs had the "Six Packs To Go" mods and then were converted back to vacuum at some point, that may be why they are not working properly. Mechanical vs Vacuum 6 pack setup
[Re: floyd]
#2649468
04/27/19 03:49 AM
04/27/19 03:49 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Yours if you want any of this. Yeah I think I have a couple of those set-ups too
[Re: ratroaster]
#2651159
05/02/19 10:20 AM
05/02/19 10:20 AM
Posts: 894 uk
TiMopar
uk
Ray do you remember what the linkage looked like? Something like this? That linkage was made by 'Ansen', I used one on my A12 Bee in the olden days... worked well!
